system.math.min
Descriptionβ
Given a sequence of numerical values, returns the minimum value, also known as the "min" value.
Returns NaN (Not a Number) if passed an empty sequence.
Syntaxβ
system.math.min(values)
Parametersβ
| List[Float] | values | A sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN. |
Returnsβ
Float - The minimum value contained within the 'values' parameter, or NaN if the input was empty or null.
Scopeβ
Code Examplesβ
Example #1 - Getting the Min Value from List
# Create a list of values.
values = [3.5, 5.6, 7.8, 7.4, 3.8]
# Prints the resulting value.
print system.math.min(values)
Example #2 - Getting the Min Value from Tag Values
# Create a List of Tag Paths to read
paths = ["[Sample_Tags]/ReadOnly/ReadOnlyInteger1","[Sample_Tags]/ReadOnly/ReadOnlyInteger2","[Sample_Tags]/ReadOnly/ReadOnlyInteger3","[Sample_Tags]/ReadOnly/ReadOnlyInteger4","[Sample_Tags]/ReadOnly/ReadOnlyInteger5"]
# Read the Tags, and store the complex results in a variable
values = system.tag.readBlocking(paths)
# Declare an empty list to append to later
tagValuesList = []
# For each Tag Path, iterate through our results...
for index in range(len(paths)):
# ...grab the Tag values...
tagValue = values[index].value
# ...and append them to the empty list from earlier
tagValuesList.append(tagValue)
# Print out the maximum value in the list
print system.math.min(tagValuesList)
