Jump and Anchor
Inductive University
Jump and Anchor
Watch the video
A jump is an element that moves the flow to its matching anchor. This is a convenience for when a link would be unsightly or impossible due to crossing other links. Each jump and anchor element is identified by a single character; jumps identified by X will jump to the anchor also identified by X. There can be many jumps on a chart that all jump to the same anchor.
note
Since Jumps and Anchors have separate name spaces in Parallel sections, you cannot Jump from a Parallel section to the normal chart, nor from the normal chart into a Parallel section. Attempting to do so will result in a no matching anchor error.
No Matching Anchor Error
