Schedule Management
Component Palette Icon:
This component allows for management of schedules. Schedules can be defined by specifying which days of the week and which times of day they are active on. The times of day are defined using a string of time ranges, where the times are specified in 24-hr format with dashes between the beginning and the end. Multiple ranges can be specified by separating them with commas. Examples:
8:00-17:00Valid from 8am to 5pm
6:00-12:00, 12:45-14:00Valid from 6am to noon, and then again from 12:45pm to 2pm
0:00-24:00Always valid.
Schedules that alternate weekly or daily can be specified by using the repetition settings. All repeating schedules need a starting day. For example, you could have a schedule that repeats on a weekly basis, with 1-week on and 1-week off. This schedule would be active for seven days starting on the starting day, and then inactive for the next seven days, then active for seven days, and so on. Note that the days of the week and time settings are evaluated in addition to the repetition settings. This means that both settings must be true for the schedule to be active. Also note that if you set "Repeat / Alternate" to a setting other than "Off" and you do not specify a starting day, the schedule will never be active.
Properties​
NameDescriptionProperty TypeScriptingCategory
AntialiasDraw with antialias on? Makes text smoother.boolean.antialiasAppearance
BorderThe border surrounding this component. Note that the border is unaffected by rotation.Border.borderCommon
Data QualityThe data quality code for any tag bindings on this component.int.dataQualityData
EnabledIf disabled, a component cannot be used.boolean.componentEnabledCommon
NameThe name of this component.String.nameCommon
Schedule Available Color
New in 7.9.5
Changes the color of the available times in the schedule.
Color.schedulePreviewAvailableColorAppearance
Schedule Available Text Color
New in 7.9.5
Changes the text color of events on the schedule preview.
Color.eventForegroundAppearance
StylesContains the component's styles.Dataset.stylesAppearance
Table Color
New in 7.9.5
Changes the background color of the tables, User Roles and Role Member lists. Note: When a row is selected it will revert to highlighted.
Color.tableBackgroundAppearance
Table Header Color
New in 7.9.5
Changes the background color of the table headers.
Color.tableHeaderBackgroundAppearance
Table Header Text Color
New in 7.9.5
Changes the text color of the table headers.
Color.tableHeaderTextColorAppearance
Table Text Color
New in 7.9.5
Changes the text color of the tables. Note: When a row is selected, it will revert to black.
Color.tableForegroundAppearance
Touchscreen ModeControls when this input component responds if touchscreen mode is enabled.int.touchscreenModeBehavior
VisibleIf disabled, the component will be hidden.boolean.visibleCommon
Window Color
New in 7.9.5
Changes the window background color.
Color.windowBackgroundAppearance
Window Header Color
New in 7.9.5
Changes the window header background color.
Color.windowHeaderBackgroundAppearance
Window Header Save Button Background Color
New in 7.9.5
Changes the window header save button background color.
Color.windowHeaderSaveButtonBackgroundAppearance
Window Header Save Button Text ColorChanges the window header save button text color.Color.windowHeaderSaveButtonForegroundAppearance
Window Header Text Color
New in 7.9.5
Changes the window header text color.
Color.windowHeaderForegroundAppearance
Window Text Color
New in 7.9.5
Changes the text color of the window.
Color.windowForegroundAppearance
Scripting​
See the Schedule Management Scripting Functions page for the full list of scripting functions available for this component.
Event Handlers​
Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the Component Events page.
Customizers​
Example​
Here is an example of the schedule management component and its property table.
Property NameValue
Data Quality-1
EnabledTrue
NameSchedules
Touchscreen ModeSingle-Click
VisibleTrue
