Version: 8.3
Perspective - Form
Component Palette Icon:
The Form component is a versatile container for creating dynamic and responsive forms in Perspective. It simplifies collecting and validating user input, making it easy to create professional and interactive forms.
Key features include:
  • Responsive Design: Automatically adapts layouts for different screen sizes.
  • Validation Support: Provides built-in and custom validation rules.
  • Flexible Layouts: Configure rows, columns, and widgets to meet your needs.
  • Dynamic Visibility: Conditionally display or enable form elements based on user input.
Properties​
These properties define the behavior and structure of the Form at the top level. They live directly under props on the component and control things like the form name, whether interaction is allowed, how many columns the form contains, and how validation information is tracked. Most properties support binding options. For more information, see Types of Bindings in Perspective.
NameDescriptionProperty Type
nameThe name of the form. This name will be used by handlers to identify forms and sort form submissions.String
disabledDisables all inputs and actions in the form. Default is false.Boolean
readOnlySets all inputs to read-only. Inputs remain focused but cannot be edited. Default is false.Boolean
columnsArray of column configuration objects defining the form structure. See the Columns Properties section below for more detail on configuration options.Array
actionsConfiguration object for Submit and Cancel buttons, including text, style, and behavior settings. See the Actions Properties section below for more detail on configuration options.Object
contextProvides additional context for the form, including metadata and configurations.Object
dataStores user input values using unique widget IDs.Object
validationRead-only object containing live validation results, including references to any widgets that are currently invalid.Object
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.Object
Columns Properties​
The columns object controls how columns are arranged and holds the list of individual column definitions. As columns are defined, more properties become available to configure. Most notable is the items array, which is included at the columns level and again at the rows level. All possible column properties are included in the tables below based on their property path.
alignSpecifies how rows are aligned horizontally within this column. Inherited by all items of this column. Options include start, end, center, and stretch.String
justifySpecifies how rows are aligned vertically within this column. Inherited by all items of this column. Options include start, end, center, space-between, and space-around.String
itemsAn array of column configuration objects. The number of entries in 'items' determines how many columns the form displays. See columns.items[x] Properties below for more details.Array
styleSets a style for all columns. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.Object
columns.items[x] Properties​
The items array appears under props.columns.items[x].* and control visibility and styling for an individual column, and contain the rows that make up that column.
visibleControls whether this column is shown. Default is true.Boolean
rowsA rows configuration object for the columns item. See Rows Properties below for more details.Object
styleSets a style for the column item. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.Object
rows Properties​
The rows object appears under props.columns.items[x].rows and controls how rows items inside a single column are laid out.
alignSpecifies how widgets are aligned horizontally within this row. Inherited by all items of this row. Options include start, end, center, and stretch.String
justifySpecifies how widgets are aligned vertically within this row. Inherited by all items of this row. Options include start, end, center, space-between, and space-around.String
itemsAn array of row configuration objects for this column. Each entry represents a single row. The number of entries in items determines how many rows the column displays. See rows.items[x] Properties below.Array
styleSets a style for the rows in the column. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.Object
rows.items[x] Properties​
The items array for rows appears under props.columns.items[x].rows.items[x].* and groups widgets together to control their alignment, visibility, and interaction conditions.
alignSpecifies how widgets are aligned horizontally within this row. Overrides the value inherited from the parent row configuration. Options include start, end, center, and stretch.String
justifySpecifies how widgets are aligned vertically within this row. Overrides the value inherited from the parent row configuration. Options include start, end, center, space-between, and space-around.String
visibleControls whether this row is shown. Default is true.Boolean
enabledControls whether the widgets in this row accept input. Default is true.Boolean
widgetsAn array of widget objects that exist within this row. See the Widgets section for details.Array
styleA style object applied to the row. Full menu of style options is available for text, background, margin and padding, border, shape, and miscellaneous. You can also specify a style class.Object
visibleWhen
  • id: The identifier of the widget or value source used when evaluating this condition as a string.
  • index: An optional index used when the source contains multiple values such as within arrays or lists, provided as a number.
  • value: The comparison value evaluated to determine whether the row becomes visible and may be any type.
Object
enabledWhen
  • value: The comparison value evaluated to determine whether the row becomes enabled and may be any type.
Object
Actions Properties​
Actions appear under props.actions.* and define the behavior, layout, and visibility of the action bar that contains the form’s Submit and Cancel buttons. The default form layout places this action bar at the bottom, but its position can be adjusted as needed.
disabledDisables all actions in the form. When true, Submit and Cancel buttons do not accept interaction. Default is false.Boolean
fixedDetermines whether the action bar remains fixed in place, even when scrolling.Boolean
layoutSpecifies how the contents of the action bar are arranged. Options include: row, column, row-reverse, and column-reverseObject
alignAligns actions along the cross axis. Actions can be aligned from the start, end, or center. The alignment layout will be vertical when set to row and horizontal when set to column.String
justifyJustifies actions along the main axis. Actions can be justified from the start, end, center, space-between, space-around, or space-evenly. The justification layout will be horizontal when set to row and vertical when set to column.String
submitConfiguration for the submit action. See Submit Properties below for more details.Object
cancelConfiguration for the cancel action. See Cancel Properties below for more details.Object
styleSets a style for the actions. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.Object
Submit Properties​
The Submit button configuration appears under props.actions.submit.* and defines the text, icon, behavior, event triggers, submission handling, response display, and reset logic associated with the submit action.
The Submit button is always rendered as part of the Form component’s action bar. While it can be disabled using the disabled property, it cannot be hidden. This is intended behavior, as the Form component is designed to provide a consistent submission mechanism and ensure that users always have access to a primary action for submitting form data.
disabledDisables the Submit button, preventing user interaction. Default is false.Boolean
textThe text displayed on the Submit button.String
iconConfigures the icon shown on the Submit button, including its path, color, and style.
  • path: The icon path used for the Submit button as a string.
  • color: The color applied to the icon as a string.
  • style: A style object applied to the submit icon. A full menu of style options is available and you can also specify a style class.
Object
fireComponentEventWhen true, triggers the onSubmitActionPerformed component event script.Boolean
fireSubmissionEventWhen true, sends form data to a Gateway-scoped Form Submission event script and enables the submissionHandler property.Boolean
submissionHandlerThe name of the Form Submission handler script. Only appears when fireSubmissionEvent is true.String
includeDisabledFieldValuesIncludes values from disabled widgets in the submission payload when true. Default is false.Boolean
includeHiddenFieldValuesIncludes values from hidden widgets in the submission payload when true. Default is false.Boolean
autoDisableAutomatically enables or disables the Submit button based on form validity and whether a submission is in progress.Boolean
resetOnDetermines when the form resets after submission. Determines when the form resets after submission.
  • success: Resets the form only after a successful submission response.
  • action: Resets the form immediately after the submit action occurs.
String
awaitResponseWhen true, the form waits for a Gateway response before applying reset behavior. Only applies when fireSubmissionEvent is true.Boolean
responseDisplayControls how submission responses are presented, including layout and style for the title and message areas.
  • layout: Specifies how the response area is arranged in relation to the actions as a string. Supported options include:
    • row: Places the response area horizontally next to the action bar.
    • column: Places the response area vertically above or below the action bar.
    • row-reverse: Places the response area horizontally but in reversed order.
    • column-reverse: Places the response area vertically in reversed order.
  • titleStyle: A style object applied to the title text of the response.
  • messageStyle: A style object applied to the response message text.
  • style: A style object applied to the response display container.
Note that a full menu of style options is available for each of the style properties. You can also specify a style class.
Object
styleA style object applied to the Submit button. Full menu of style options is available for text, background, margin and padding, border, shape, and miscellaneous. You can also specify a style class.Object
Cancel Properties​
Cancel button configuration appears under props.actions.cancel.* and define how the cancel action behaves, including button text, icon configuration, component event triggers, and whether the form resets when the button is pressed.
The Cancel button is always rendered as part of the Form component’s action bar. While it can be disabled using the disabled property, it cannot be hidden. This is intended behavior, as the Form component is designed to provide a consistent submission mechanism and ensure that users always have access to a primary action for submitting form data.
disabledDisables the Cancel button, preventing user interaction.Boolean
textThe text displayed on the Cancel button.String
iconControls the appearance of the Cancel button’s icon, including its path, color, and style.
  • path: The icon path used for the Cancel button as a string.
  • style: A style object applied to the cancel icon. A full menu of style options is available and you can also specify a style class.
Object
styleA style object applied to the Cancel button. Full menu of style options is available for text, background, margin and padding, border, shape, and miscellaneous. You can also specify a style class.Object
fireComponentEventWhen true, triggers the onCancelActionPerformed component event script.Boolean
resetResets all form fields to their default values when the Cancel button is pressed.Boolean
Widgets​
Widgets live at deeper paths under props.columns.items[x].rows.items[x].widgets[x]. However, they function as their own complete layer of configuration where each widget represents a single form input like a text field, dropdown, toggle, or slider. All widgets share a common set of base properties, and each widget type introduces its own additional configuration options.
Widget Properties​
idA unique identifier for the widget. Used in scripts and the form’s data object.String
domIDThe HTML ID attribute applied to the widget for styling or scripting purposes.String
typeDetermines which widget configuration is available. See the Widget Types section for a list of available widgets.String
visibleControls whether the widget is shown. Default is true.Boolean
enabledControls whether the widget accepts input. Default is true.Boolean
readOnlySets all inputs to read-only. Inputs remain focused but cannot be edited. This property becomes available when text, email, URL, password, number, or tel widgets are selected. Default is false.Boolean
defaultValueThe default value of this form field that is used as the value when the form is reset.String
layoutControls how the widget is positioned within the row.Object
labelText and styling applied to the widget’s label.Object
infoSupplemental help text or a tooltip displayed alongside the widget.Object
tabIndexDetermines keyboard navigation order. Default is 0.Integer
styleSets a style for the selected widget. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.Object
Widget Types​
Each widget’s type property controls which additional properties become available under props.columns.items[x].rows.items[x].widgets[x].*. These properties define the behavior, validation rules, icons, messages, and styling for the selected widget type. Widget types include:
Text​
A single-line text input for general purpose string entry, such as names, identifiers, or short notes. The text properties appear under props.columns.items[x].rows.items[x].widgets[x].text.*
Text Properties
autoCompleteProvides browser-level autocomplete hints.String
placeholderText displayed when the field is empty.String
validationConfigures validation constraints, error messages, and visual feedback for this widget. See the Widget Validation section for a list of available configurations.Object
styleSets a style for this widget. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.Object
Email​
A single-line input optimized for capturing email addresses, with option support for multiple comma-separated entries. The email widget properties appear under props.columns.items[x].rows.items[x].widgets[x].email.*
Email Properties
autoCompleteProvides autocomplete hints suitable for email entry.String
multipleAllows multiple comma-separated email entries.Boolean
URL​
A field for entering and validating URLs, typically used for web links or resource references. The URL widget properties appear under props.columns.items[x].rows.items[x].widgets[x].url.*
URL Properties
autoCompleteProvides autocomplete hints suitable for URL entry.String
Password​
A masked text input used for sensitive values such as passwords or authentication tokens. Password widget properties appear under props.columns.items[x].rows.items[x].widgets[x].password.*
Password Properties
autoCompleteProvides autocomplete hints for password entry.String
Number​
A numeric input that restricts entry to numbers and supports min, max, and step validation. The number widget properties appear under props.columns.items[x].rows.items[x].widgets[x].number.*
Decimal Input
Decimal input requires constraints.step.enabled to be enabled. See Widget Validation for details on configuration.
Number Properties
autoCompleteProvides autocomplete hints suitable for numeric entry.String
Tel​
A phone-number–oriented input that supports pattern validation for telephone formats. The tel widget properties appear under props.columns.items[x].rows.items[x].widgets[x].tel.*
Tel Properties
autoCompleteProvides autocomplete hints for phone number entry.String
Text Area​
A multi-line input for longer free-form text such as comments or descriptions. The text area widget properties appear under props.columns.items[x].rows.items[x].widgets[x].text-area.*
Text Area Properties
autoCompleteProvides autocomplete hints for multi-line text.String
placeholderText displayed when the text area is empty.String
spellCheckEnables or disables browser spell checking.Boolean
wrapDetermines how text wraps within the text area.String
Radio​
A group of mutually exclusive options where the user selects exactly one value. The radio widget properties appear under props.columns.items[x].rows.items[x].widgets[x].radio.*
Radio Properties
optionsDefines the list of available radio options, including their labels and returned values.
  • text: The label text displayed for the option as a string.
  • value: The unique value of the radio option to be evaluated when selected. May be any type.
Array
layoutLayout configuration for the group of radio options.Object
alignAlignment of radio options within the group.String
justifySpacing behavior between options.String
textPositionPosition of the label text relative to the radio icon.String
selectedIconDefines the icon shown when a radio option is selected, including its path, colors, and styles.
  • path: The icon path used for the selected state as a string.
  • color.enabled: The color used when the icon is enabled as a string.
  • color.disabled: The color used when the icon is disabled as a string.
  • style: A style object applied to the selected icon. A full menu of style options is available and you can also specify a style class.
Object
unselectedIconDefines the icon shown when a radio option is not selected, including its path, enabled and disabled colors, and styles.
  • path: The icon path used for the unselected state as a string.
  • color.enabled: The color used when the option is enabled as a string.
  • color.disabled: The color used when the option is disabled as a string.
  • style: A style object applied to the unselected icon. A full menu of style options is available and you can also specify a style class.
Object
validationConfigures validation constraints, error messages, icons, and style for this widget. See the Widget Validation section for a full list of available validation properties.Object
styleA style object applied to the widget. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.Object
optionStyleA style object applied to each radio option. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.Object
Checkbox​
A group of independent options where each item can be checked or unchecked. The checkbox widget properties appear under props.columns.items[x].rows.items[x].widgets[x].checkbox.*.
Checkbox Properties
typeControls the checkbox behavior and visual style.String
optionsDefines the set of checkbox options, including labels, values, and whether each supports a tri-state mode.
  • text: The label text to display for the checkbox option as a string.
  • value: The unique value associated with the checkbox option, evaluated when the option is selected and may be any type.
  • triState: Allows the option to represent checked, unchecked, or indeterminate as a boolean.
Array
layoutLayout configuration for the group of checkbox options.Object
alignAlignment of the checkbox options within the group.String
justifySpacing behavior between checkbox options.String
textPositionPosition of the label text relative to the checkbox icon.String
checkedIconDefines the icon shown when the checkbox is in the checked state, including its path, enabled and disabled colors, and styles.
  • path: The icon path used when the checkbox is checked as a string.
  • style: A style object applied to the checked icon. A full menu of style options is available and you can also specify a style class.
Object
indeterminateIconDefines the icon used when the checkbox is in an indeterminate state, along with its colors and style.
  • path: The icon path used when the checkbox is in an indeterminate state as a string.
  • style: A style object applied to the indeterminate icon. A full menu of style options is available and you can also specify a style class.
Object
uncheckedIconDefines the icon shown when the checkbox is not selected, including path, enabled and disabled colors, and styles.
  • path: The icon path used when the checkbox is unchecked as a string.
  • style: A style object applied to the unchecked icon. A full menu of style options is available and you can also specify a style class.
Object
styleA style object applied to the checkbox group. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.Object
optionStyleA style object applied to each checkbox option. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.Object
Toggle​
A switch-style selection control used for boolean or labeled on/off choices. The toggle widget properties appear under props.columns.items[x].rows.items[x].widgets[x].toggle.*
Toggle Properties
typeControls the toggle behavior and visual style. Options include boolean and string types.String
optionsDefines the set of toggle options, including the displayed text and the value returned when selected.
  • text: The label text to display for the toggle option as a string.
  • value: The unique value associated with the toggle option, evaluated when the option is selected and may be any type.
Array
layoutLayout configuration for the group of toggle options.Object
alignAlignment of the toggle options within the group.String
justifySpacing behavior between toggle options.String
textPositionPosition of the label text relative to the toggle control.String
colorDefines the colors used for selected and unselected toggle options.
  • selected: The color used when the toggle option is selected as a string.
  • unselected: The color used when the toggle option is not selected as a string.
Object
styleA style object applied to the toggle group. Full menu of style options is available for text, background, margin and padding, border, shape, and miscellaneous. You can also specify a style class.Object
optionStyleA style object applied to each toggle option. Full menu of style options is available for text, background, margin and padding, border, shape, and miscellaneous. You can also specify a style class.Object
Slider​
A draggable control used to select a numeric value within a defined range. The slider widget properties appear under props.columns.items[x].rows.items[x].widgets[x].slider.*.
Slider Properties
labelsControls how tick labels appear along the slider track, including whether they show and how often they appear.
  • show: Determines whether tick labels are displayed along the slider track as a boolean.
  • interval: The interval between displayed label values as a number.
Object
maxThe maximum value allowed by the slider.Number
minThe minimum value allowed by the slider.Number
stepThe increment applied when adjusting the slider value.Number
handleColorThe color applied to the slider handle.String
railColorThe color applied to the background rail track.String
trackColorThe color applied to the filled portion of the slider track.String
styleA style object applied to the slider. Full menu of style options is available for text, background, margin and padding, border, shape, and miscellaneous. You can also specify a style class.Object
A collapsible list of options used to select one or multiple values from a predefined list. The dropdown widget properties appear under props.columns.items[x].rows.items[x].widgets[x].dropdown.*.
Dropdown Properties
optionsDefines the list of dropdown options, including their labels, values, and disabled state.
  • value: The underlying value associated with the option and may be any type.
  • label: The text displayed for the option as a string.
  • isDisabled: Determines whether the option is selectable as a boolean.
Array
multiselectAllows multiple options to be selected.Boolean
wrapMultiSelectValuesWraps selected values instead of truncating them.Boolean
placeholderControls the placeholder text, color, and icon shown when no selection has been made.
  • text: Placeholder text shown when no value is selected as a string.
  • color: The color applied to the placeholder text as a string.
  • icon: The icon configuration for the placeholder as an object.
Object
search
New in 8.3.8
Allows users to enter text to search for results. Configurable search options include:
  • enabled: Whether options are searchable by typing text into the field. Default is true. Value is boolean.
  • matching: Whether the search string must match from the start or may match any position of an option. Value is string.
  • noResultsText: The text to display in the dropdown when no options match the search. Default is "No results found". Value is string.
  • searchParam: The text being searched for. This property is read-only, and any input in this field will have no effect and will be overwritten. Value is string.
Object
showClearIcon
New in 8.3.8
Whether to render a button allowing a user to clear the selection. Default is false.
Boolean
allowCustomOptions
New in 8.3.8
Whether a user may enter a custom value to be submitted. Default is false.
While set to True, typing a value that doesn't match one of the existing options from the session will provide the user with a Create option. Selecting Create will set props.value to the new option. Creating a custom option in this way does not change the value of props.options. The custom option is simply a means to allow the user to type a custom value into the component.
Boolean
textAlignAlignment of the displayed text within the field.String
minMenuHeightThe minimum height for the dropdown menu.Number
maxMenuHeightThe maximum height for the dropdown menu.Number
styleA style object applied to the dropdown. Full menu of style options is available for text, background, margin and padding, border, shape, and miscellaneous. You can also specify a style class.Object
optionStyleA style object applied to each dropdown option. Full menu of style options is available for text, background, margin and padding, border, shape, and miscellaneous. You can also specify a style class.Object
Date Picker​
A control for selecting calendar dates with formatting and locale options. The date picker widget properties appear under props.columns.items[x].rows.items[x].widgets[x].date-picker.*.
Date Picker Properties
defaultToNowUses the current date as the initial value when enabled.Boolean
displayTypeControls how the date picker appears, such as inline or dialog.String
minDateThe earliest selectable date.String
maxDateThe latest selectable date.String
formatThe format string used to display the date.String
placeholderThe text displayed when no date is selected.String
localeThe locale used for date formatting and localization.String
dismissOnSelectCloses the date picker when a date is selected.Boolean
validationConfigures validation constraints, error messages, icons, and style for this component. See the Widget Validation section for a full list of available validation properties.Object
styleA style object applied to the date picker. Full menu of style options is available for text, background, margin and padding, border, shape, and miscellaneous. You can also specify a style class.Object
modalStyleA style object applied to the date picker modal or popup. Full menu of style options is available for text, background, margin and padding, border, shape, and miscellaneous. You can also specify a style class.Object
Time Picker​
A control for selecting times of day, with optional spinner or typed entry. The time picker widget properties appear under props.columns.items[x].rows.items[x].widgets[x].time-picker.*.
Time Picker Properties
defaultToNowUses the current time as the initial value when enabled.Boolean
minTimeThe earliest selectable time.String
maxTimeThe latest selectable time.String
showSpinnersShows increment and decrement controls for adjusting time.Boolean
formatThe format string used to display the time.String
localeThe locale used for time formatting and localization.String
styleA style object applied to the time picker. Full menu of style options is available for text, background, margin and padding, border, shape, and miscellaneous. You can also specify a style class.Object
Date and Time Picker​
A combined control for selecting both a date and a time. The date and time Picker widget properties appear under props.columns.items[x].rows.items[x].widgets[x].date-time-picker.*.
Date and Time Picker Properties
defaultToNowUses the current date and time as the initial value when enabled.Boolean
displayTypeControls how the picker is displayed, such as inline or dialog.String
minDateThe earliest selectable timestamp.String
maxDateThe latest selectable timestamp.String
formatThe format string used to display the date and time.String
placeholderThe text displayed when no value is selected.String
localeThe locale used for formatting and localization.String
dismissOnSelectCloses the picker when a value is selected.Boolean
styleA style object applied to the date and time picker. Full menu of style options is available for text, background, margin and padding, border, shape, and miscellaneous. You can also specify a style class.Object
modalStyleA style object applied to the picker modal or popup. Full menu of style options is available for text, background, margin and padding, border, shape, and miscellaneous. You can also specify a style class.Object
File Upload​
New in 8.3.8
A control for selecting and uploading one or more files as part of the form. The file upload widget properties appear under props.columns.items[x].rows.items[x].widgets[x].file-upload.*.
File Upload Properties
Widget Validation​
The constraints, icon, messages, and style groups make up the validation settings for widgets. Although these groups appear across multiple widget types, not every sub-property is shared. Refer to the Supported Widgets column to see which widgets implement each sub-property.
NameDescriptionProperty TypeSupported Widgets
constraints.maxLength.enabledEnables validation that checks whether the input exceeds the maximum allowed length.Boolean
  • text
  • email
  • password
  • url
  • tel
  • text-area
constraints.maxLength.valueSpecifies the maximum number of characters allowed.Number
  • text
  • email
  • password
  • url
  • tel
  • text-area
constraints.minLength.enabledEnables validation that checks whether the input meets the minimum required length.Boolean
  • text
  • email
  • password
  • url
  • tel
  • text-area
constraints.minLength.valueSpecifies the minimum number of characters required.Number
  • text
  • email
  • password
  • url
  • tel
  • text-area
constraints.pattern.enabledEnables validation that checks whether the input must match a regular expression.Boolean
  • text
  • email
  • password
  • url
  • tel
constraints.pattern.valueSpecifies the regular expression the input must match.String
  • text
  • email
  • password
  • url
  • tel
constraints.required.enabledEnables validation that checks whether a value has been provided.BooleanAll types
constraints.minSpecifies the lowest numeric value allowed.Numbernumber
constraints.maxSpecifies the highest numeric value allowed.Numbernumber
New in 8.3.4
Enables validation that enforces the specific interval between numeric values as set by the step.value property.
Note: When constraints are enabled, this property must also be enabled to allow decimal values. Otherwise, input is limited to integers.
Booleannumber
constraints.step.value
New in 8.3.4
Defines the interval between allowed numeric values. Set to any to allow any value.
Stringnumber
constraints.fileSizeLimit.value
New in 8.3.8
Specifies the maximum size, in megabytes, allowed for each uploaded file.
Numberfile-upload
constraints.maxUploads.enabled
New in 8.3.8
Enables validation that limits the number of files that can be uploaded.
Booleanfile-upload
constraints.maxUploads.value
New in 8.3.8
Specifies the maximum number of files that can be uploaded.
Numberfile-upload
constraints.supportedFileTypes.enabled
New in 8.3.8
Enables validation that restricts uploads to specific file types.
Booleanfile-upload
constraints.supportedFileTypes.value
New in 8.3.8
Specifies the list of allowed file types.
Arrayfile-upload
icon.pathSpecifies the icon displayed when validation feedback becomes active.StringAll types
icon.colorSpecifies the color applied to validation icons.StringAll types
icon.styleSpecifies the style applied to validation icons.ObjectAll types
messages.valueMissingDisplays when a required field has no value.StringAll types
messages.patternMismatchDisplays when input does not match the required pattern.String
  • text
  • email
  • password
  • url
  • tel
messages.tooLongDisplays when input exceeds the maximum allowed length.String
  • text
  • email
  • password
  • url
  • tel
  • text-area
messages.tooShortDisplays when input does not meet the minimum required length.String
  • text
  • email
  • password
  • url
  • tel
  • text-area
messages.typeMismatchDisplays when the value does not match the expected type.String
  • email
  • url
messages.rangeUnderflowDisplays when a numeric value is lower than the minimum allowed.String
  • number
  • slider
messages.rangeOverflowDisplays when a numeric value is higher than the maximum allowed.String
  • number
  • slider
messages.fileSizeLimit
New in 8.3.8
Displays when an uploaded file exceeds the maximum allowed file size.
Stringfile-upload
messages.maxUploads
New in 8.3.8
Displays when the amount of uploaded files exceeds the maximum number of allowed uploads.
Stringfile-upload
messages.supportedFileTypes
New in 8.3.8
Displays when an uploaded file is not an allowed file type.
Stringfile-upload
validation.styleSpecifies styles applied to validation messages and indicators.ObjectAll types
Decimal Input in Number Widgets
For the Number widget type, enabling constraints without enabling constraints.step.enabled limits input to integer values. To allow decimal values, enable constraints.step.enabled and set constraints.step.value to the interval you want to allow, or to any.
Scripting​
See the Perspective - Form Scripting page for the full list of scripting functions available for this component.
Examples​
Create a Basic Form Layout with Validation​
When a Form component is first added to a view, it will have a single column containing two rows for the header and input. This example demonstrates how to further configure multiple rows and validation for email and phone number fields.
To configure the Form component with validation:
  1. Drag a Form component onto your view.
  2. Select the Form component and set props.name to Basic Form in the Property Editor.
  3. Edit the header row.
    1. Navigate to columns.items[0].rows.items[0].widgets.
    2. Expand 0, then set the following values:
      • id to header
      • label.text to Simple Name and Address Entry Form
      • (Optional) Delete or update info.text. In this example, each info.text value has been deleted.
  4. Edit the existing input row for first and last name.
    1. Navigate to columns.items[0].rows.items[1].widgets.
      • id to firstName
      • type to text
      • text.placeholder to Enter your first name...
      • label.text to First Name
    3. Add a second widget to the same row.
      1. Click the Add icon next to widgets.
      2. Expand 1, then set the following values:
        • id to lastName
        • type to text
        • text.placeholder to Enter your last name...
        • label.text to Last Name
  5. Add a row for the email field.
    1. Navigate to columns.items[0].rows.items and click the Add icon next to items.
    2. Navigate to rows.items[2].widgets.
    3. Expand 0, then set the following values:
      • id to email
      • type to email
      • text.placeholder to Enter your email...
      • label.text to Email Address
    4. Expand email.validation.constraints.pattern, then set the following values:
      • enabled to true
      • value to ^[a-zA-Z0-9._%+\-]+@[a-zA-Z0-9.\-]+\.[a-zA-Z]{2,}$
    5. Expand email.validation.constraints.required, then set enabled to true.
  6. Add a row for the phone number field.
    2. Navigate to rows.items[3].widgets.
      • id to phoneNumber
      • type to tel
      • text.placeholder to Enter your phone number...
      • label.text to Phone Number
    4. Expand tel.validation.constraints.required, then set enabled to true.
    5. Expand tel.validation.constraints.pattern, then set the following values:
      • enabled to true
      • value to ^\+?[1-9]\d{1,14}$
Properties Used​
PropertyValue
props.nameBasic Form
props.columns.items[0].rows.items[0].widgets[0].idheader
props.columns.items[0].rows.items[0].widgets[0].label.textSimple Name and Address Entry Form
props.columns.items[0].rows.items[1].widgets[0].idfirstName
props.columns.items[0].rows.items[1].widgets[0].typetext
props.columns.items[0].rows.items[1].widgets[0].text.placeholderEnter your first name...
props.columns.items[0].rows.items[1].widgets[0].label.textFirst Name
props.columns.items[0].rows.items[1].widgets[1].idlastName
props.columns.items[0].rows.items[1].widgets[1].typetext
props.columns.items[0].rows.items[1].widgets[1].text.placeholderEnter your last name...
props.columns.items[0].rows.items[1].widgets[1].label.textLast Name
props.columns.items[0].rows.items[2].widgets[0].idemail
props.columns.items[0].rows.items[2].widgets[0].typeemail
props.columns.items[0].rows.items[2].widgets[0].text.placeholderEnter your email...
props.columns.items[0].rows.items[2].widgets[0].label.textEmail Address
props.columns.items[0].rows.items[2].widgets[0].email.validation.constraints.pattern.enabledtrue
props.columns.items[0].rows.items[2].widgets[0].email.validation.constraints.pattern.value^[a-zA-Z0-9._%+\-]+@[a-zA-Z0-9.\-]+\.[a-zA-Z]{2,}$
props.columns.items[0].rows.items[2].widgets[0].email.validation.constraints.required.enabledtrue
props.columns.items[0].rows.items[3].widgets[0].idphoneNumber
props.columns.items[0].rows.items[3].widgets[0].typetel
props.columns.items[0].rows.items[3].widgets[0].text.placeholderEnter your phone number...
props.columns.items[0].rows.items[3].widgets[0].label.textPhone Number
props.columns.items[0].rows.items[3].widgets[0].tel.validation.constraints.required.enabledtrue
props.columns.items[0].rows.items[3].widgets[0].tel.validation.constraints.pattern.enabledtrue
props.columns.items[0].rows.items[3].widgets[0].tel.validation.constraints.pattern.value^\+?[1-9]\d{1,14}$
Try it Yourself: Form Component Contingent Actions Guided Tutorial​
Open Training Exercise
