Version: 8.3
Perspective - Text Area
Component Palette Icon:
Suitable for multi-line text display and editing. Will scroll vertically on demand. Horizontal scroll is determined by the "wrap" property.
Properties​
NameDescriptionProperty Type
textText to display.value: string
placeholderText displayed when Text Area is empty.value: string
enabledIf true, user is allowed to alter text.value: boolean
deferUpdatesWhen true, updates to props.text will be deferred until focus is lost or enter is pressed.value: boolean
rejectUpdatesWhileFocusedWhen true, props.text will not accept updates from external sources while focused.value: boolean
resizeSets whether text is resizable, and if so, in which direction: none, both, horizontal, or vertical.value: string
wrapSpecifies how to wrap text: hard, soft, or off. (Soft wrap is the break resulting from a line wrap or word wrap. Hard wrap is an intentional break, which moves text to the next line, or creates a new paragraph).value: string
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
spellcheckWhen true, text containing potential spelling errors will be underlined in red while the text is being edited in a launched session. Be aware there may be some slight behavioral differences in spellcheck error detection depending on the session browser.value: boolean
Component Events​
Example​
This example shows the Text Area in two states: the top image is with text entered and the bottom image is without text entered.
PropertyValue
props.textData Point 01: xy4, zBeta 3
Data Point 02: xy12, zBeta 45
Notes: Example of how a longer sentence can wrap (or not) around to the next line. Enter was pressed between each of these three lines.
props.placeholderLab Data Entry
props.wrapoff
