Version: 8.3
Perspective - Button
Component Palette Icon:
The Button component is a versatile component, that is used to initiate some sort of action in response to being pressed. It can be used for showing status, as well. For example, you can configure buttons to be active or inactive, change color, text or any other property, and you can alter these configurations in response to conditions in your project. Button components support icons as well. For an example, see Example 2 below.
To get buttons to do things, you configure one or more Actions that occur following an Event. For instance, you might call a script action on the onActionPerformed component event, which triggers when the button is pressed.
The Button component has two pre-configured variants: Primary and Secondary.
Properties​
NameDescriptionProperty Type
textText to display on a button. Text can also be entered directly on the button by deep selecting the component, which enables inline editing. Changes are immediately reflected in the text property field.value: string
textStyleStyle properties that are directly applied to the text within the Button component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
primaryToggle between default primary and secondary button style. Default is true.value: boolean
enabledEnables button interaction. Default is true.value: boolean
imageAn optional image embedded in the button.
  • source: The image source URL. It could be a URL to an image on the internet or Gateway, or even an embedded image. Value is string. For an image already in the Image Management console, use /system/images/{path to your image}. For example:
    /system/images/Builtin/icons/24/lightbulb_on.png
  • icon: An image path used to augment the writingState of the component by placing an image next to it.
    • color: Color of the icon. Can also assign color in "fill" of the style property. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector.
  • width: Width of the button image in pixels. Value is numeric.
  • height: Height of the button image in pixels. Value is numeric.
  • position: Horizontal position of the image within the button relative to the text: left, center, right, top, or bottom. Value is string.
  • style: Sets a style for the image. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.
object
alignAligns the text and image (if present) along the cross axis. Vertical if imagePosition is top or bottom, otherwise it's horizontal. Options are start, center, end, and stretch. Default is center.value: string
justifyJustifies the text and image (if present) along the main axis. Horizontal if the imagePosition is top or bottom, otherwise it's vertical. Options are start, center, end, space-around, space-between, and space-evenly. Default is center.value: string
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
Component Events​
Examples​
Example 1​
PropertyValue
props.textComplete
props.image.source/system/images/Builtin/icons/48/check2.png
props.image.positionright
props.textStyle.color#000000
props.justifyspace-evenly
props.style.backgroundColor#D5D5D5
props.style.borderStylesolid
props.style.borderColor#000000
props.style.borderWidth2px
Example 2​
PropertyValue
props.textSave
props.textStyle.color#00AC00
props.image.source/system/images/Builtin/icons/48/disk_green.png
props.image.positiontop
props.image.width40
props.image.height40
props.alignend
props.justifyspace-between
props.style.backgroundColor#FFFFFF
props.style.borderStyleinset
props.style.borderWidth5px
props.style.borderColor#00AC00
