Version: 8.3
Perspective - View Object
This is the view itself. A view has properties that control the view size, defines how tags are dropped into a view, and settings for loading client views. The view properties are the same for each container type. View properties are displayed in the Perspective Property Editor when you click on the view in the Project Browser.
Properties​
NameDescriptionProperty Type
defaultSizeDefault size of the container.
  • width: Width of the view. Default is 800px. Value is numeric.
  • height: Height of the view. Default is 800px. Value is numeric.
value: numeric
dropConfigProvides an opportunity to automatically create an instance of this view via tag drop. Click to see dropConfig properties. See the Drop Configuration page for more information.object
loadingOptions for loading the view.
  • mode: Provides two options for loading views, particularly for views with a high number of components: blocking and non-blocking. Blocking loads faster for views with fewer components. Non-blocking loads views with a large number of components in chunks. Default is 'non-blocking'.
    Views set to non-blocking will only wait patiently for five seconds if they have not been called. Value is string.
object
inputBehaviorControls whether the internal properties of object-typed input and bi-directional parameters are merged with existing default values or whether the object-typed parameter should be strictly replaced with the supplied values.
If "replace" is selected, and an object-typed parameter is supplied which does not contain a key for a default value, then that default value will not be used. Default is replace. Examples are included below.
object
dropConfig Properties​
udtsThese settings allow for the automatic creation of this view when a UDT instance is dragged onto another view, using _this_ view to represent the UDT. A parameter is passed into the view, allowing the view to reference the UDT.
  • type: The name of the UDT to associate with this view. Value is string.
  • param: Name of the parameter on this view that the UDT member values will be passed to. Value is string.
  • action: Value is boolean.
    • bind: Automatically configures a tag binding on the parameter (specified by param) to the UDT.
    • path: Passes in a tag path string on the parameter (specified by param)
object
dataTypesThese settings allow for the automatic creation of this view when a standard tag is dragged onto another view. A parameter is passed into the view, allowing the view to reference the tag.
  • type: The tag data type to associate with this view. Value is string.
  • param: Name of the parameter to pass into this view. Value is string.
    • bind: Automatically configures a tag binding on the parameter (specified by param) to the tag.
object
inputBehavior Examples​
Defined “default” parameter:
myObject: {
myParamOne: "One",
myParamTwo: "Two"
Supplied parameter from Embedding Component:
myObject: {
myParamOne: "1",
myParamThree: "3"
If “merge” is selected:
myObject: {
myParamOne: "1",
myParamTwo: "Two",
myParamThree: "3"
If “replace” is selected:
myObject: {
myParamOne: "1",
myParamThree: "3"
Note that there is no value for myParamTwo, so any references to this property will fault.
Component Events​
