Version: 8.3
Perspective - Checkbox
Component Palette Icon:
A Checkbox is a familiar component that represents a bit - it is either on (selected) or off (not selected). In addition, the 'triState' property can be enabled, adding a third state to represent an indeterminate value. It is functionally equivalent to the Toggle Switch component.
The DateTime Picker component has two pre-configured variants: Text Right and Text left.
Properties​
NameDescriptionProperty Type
selectedOutput value for checkbox.value: boolean
textLabel for the checkbox. Label text can also be entered directly by deep selecting the checkbox component, which enables inline editing. Changes are immediately reflected in the text property field.value: string
textPositionWhere to place the label text in relation to the checkbox: top, right, bottom, or left.value: string
enabledWhether the user can currently interact with the checkbox.
Note: If the component is disabled, scripts can still run on the component. For example, if you add a script action to the onClick event, the script will fire when the user clicks on the Checkbox.
value: boolean
triStateWhether the checkbox supports a third state of "indeterminate" - effectively 'null' or 'no choice'.value: boolean
checkedIconSettings for the appearance of the check box's icon when it is selected (checked).
  • path: Path to the icon source, in format: library/IconName. For more information on icons, see the Images, and Icons in Perspective page. Value is string.
  • color: Settings for the fill color for the icon.
    • enabled: Color of the icon when enabled. Can be a named color. Value is string.
    • disabled: Color of the icon when disabled. Can be a named color. Value is string.
  • style: Sets a style for the icon. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.
object
uncheckedIconSettings for the appearance of the check box's icon when it is not selected.
object
indeterminateIconSettings for the appearance of the check box's icon when it is in the indeterminate state. Only applies if props.triState is set to true.
object
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
Component Events​
Examples​
Example 1​
PropertyValue
props.textCheckbox 1
props.textPositionleft
props.triStatetrue
Example 2​
PropertyValue
props.textCheckbox 2
props.selectednull
Example 3​
PropertyValue
props.textCheckbox 3
props.textPositiontop
props.enabledfalse
props.selectedfalse
