Perspective - File Upload Scripting
This page details the various scripting, component, and extension functions available for Perspective's File Upload component.
Component Events​
onFileReceived​
Provides a chance to handle file data uploaded to the component.
This component event is designed to be used in tandem with a script action. Within the script action, special properties and methods are available on the event object, which is passed to the script action as a parameter.
event.file.name​
Object Path
- event.file.name
Type
- String
Description
- The name of the uploaded file.
event.file.size​
Object Path
- event.file.size
Type
- Integer
Description
- The size of the uploaded file in bytes.
event.file.copyTo(filePath)​
Object Path
- event.file.copyTo()
Description
- Saves the uploaded file at a location accessible to the Gateway.
Parameters
- String filePath - The path to where the file should be saved on the Gateway.
Return
- None
event.file.getBytes()​
Object Path
- event.file.getBytes()
Description
- Fetches the incoming file data. Suitable for further data processing.
Parameters
- None
Return
- byteArray - The raw data of the incoming file.
event.file.getString()​
Object Path
- event.file.getString()
Description
- Fetches the incoming file data and attempts to parse it as a string via UTF-8 (Eight-bit UCS Transformation Format) encoding. Although this defaults to UTF-8, other character sets can be used. For example, getString("UTF_16BE").
Parameters
- None
Return
- String - The raw data of the incoming file as a string.
onUploadsCleared​
This event is fired when the user has cleared all uploads, but not while uploads are still in progress.
event.files​
Object Path
- event.files
Type
- List
Description
- A list containing a number of PyJsonObjectAdapters, where each adapter contains a
name
(string) andsize
in bytes (integer bytes)
# Prints a message per file showing its name and file size
messageTemplate = "Cleared %s with a size of %d bytes"
for file in event.files:
system.perspective.print(messageTemplate % (file.name, file.size))
# Alternatively you can access individual items:
messageTemplate = "The name of the first file cleared is: %s"
system.perspective.print(messageTemplate % event.files[0].name)
Component Functions​
.clearUploads()​
Description
Resets the File Upload component to its default state
noteclearUploads() does not remove or delete uploaded files from the Gateway. Clearing uploads does not undo any actions triggered by the onFileReceived() Component Event.
Parameters
- None
Return
- Nothing
Extension Functions​
