Version: 8.3
Perspective - Form Scripting
This page details the various scripting, component, and extension functions available for Perspective's Form component. Scripting allows you to customize form behavior, handle validation dynamically, and respond to user actions.
Component Events​
The Perspective Event Types Reference page describes all possible event types for Perspective components. Not all event types apply to every component. For more information on configuring events, see Component Events and Actions.
onChange​
This event triggers whenever a form's input value changes.
Properties​
PropertyTypeDescription
event.inputKeyStringThe unique key identifying the input that triggered the change.
event.newValueObjectThe new value of the input after the change.
event.oldValueObjectThe previous value of the input before the change occurred.
event.indexIntegerThe index of the input if multiple inputs share the same key, such as in a repeater or table. Optional.
onSuccess​
This event triggers when a form submission completes successfully.
Properties​
eventObjectThe success response object returned after submission.
See Form Submission for handling form data on submission.
onError​
This event triggers when a form submission fails.
Properties​
eventObjectThe error response object returned from the submission.
See Form Submission for handling errors.
onCancelActionPerformed​
If configured, this component event fires when the Form's cancel action is clicked.
Properties​
eventObjectA JSON object containing all form input data to be cancelled.
onSubmitActionPerformed​
If configured, this component event fires when the Form's submit action is clicked.
Properties​
eventObjectA JSON object containing all form input data to be submitted.
Component Functions​
.setCustomValidity(message, inputKey, index)​
Sets a custom validation message for a specific input field in the form.
ParameterTypeDescription
messageStringThe custom validation message to display for this input.
inputKeyStringThe unique key identifying the input field.
indexIntegerThe index of the input if multiple inputs share the same key. Optional.
Return​
None
Example​
To set a custom validation message for an email input field:
self.getSibling("Form").setCustomValidity("Please provide a valid email address.", "email")
info
This message will persist until the field is corrected or the form is reset.
.reset()​
Resets all form inputs to their default values.
None
Return​
None
Example​
To reset the form inputs to their default state:
self.getSibling("Form").reset()
.submit(preventInvalid)​
Submits the form, triggering onSuccess if successful or onError if submission fails.
preventInvalidBooleanWhen true, prevents the form from submitting if it is invalid. Optional.
Return​
None
Example​
To submit the form with validation check enabled:
self.getSibling("Form").submit(preventInvalid=True)
Extension Functions​
This component does not have any extension functions associated with it.
