Version: 8.3
Perspective - Radio Group
Component Palette Icon:
The Radio Group allows you to create multiple radio buttons in a single container. The number of radio buttons in the group is determined by the number of elements in the "radios" object. Only one radio button in a group may be selected at a time. Radio groups are a good way to let the user choose just one of a number of options. If multiple selections are expected, the Checkbox or Dropdown components can be used.
The Radio Group component has three pre-configured variants:
  • Text Right - Default layout with text on the right of the radio button.
  • Text Left - Layout with text on the left of the radio button.
  • Multiple - Layout with multiple radio buttons and text on the right.
Properties​
NameDescriptionProperty Type
valueThe value of the selected radio.value: string, integer, boolean, or null
indexThe index of the selected node.value: integer
radiosList of radios that make up this group.
  • enabled:
    New in 8.3.5
    Whether the user is allowed to select this radio. Value is boolean.
  • text: Text to pair with this radio. Value is string.
  • selected: If 'true,' this radio is selected. Value is boolean.
  • value: The value of the radio to be evaluated when selected. Value is numeric.
  • style:
    New in 8.3.5
    Sets a style for this radio. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.
array
orientationPlacement of the Radio Button: row or column. Default is row.value: string
alignAlign radios along the cross axis. Vertical if orientation is set to row; horizontal if orientation is set to column.value: string
justifyJustify radios along the main axis. Horizontal if orientation is set to row; vertical if orientation is set to column.value: string
textPositionWhere to place the label text in relation to the Radio Button: top, right, bottom, or left. Default is right.value: string
enabledIf true, user is allowed to select a radio. Default is true.
Note: If the component is disabled, scripts can still run on the component. For example, if you add a script action to the onClick event, the script will fire when the user clicks on the Radio Button.
value: boolean
selectedIconSettings for the appearance of the radio's icon when it is selected.
  • path: Path to the icon source, in format: library/IconName. For more information on icons, see the Images, and Icons in Perspective page. Value is string.
  • color: Settings for the fill color for the icon.
    • enabled: Color of the icon when enabled. Can be a named color. Value is string.
    • disabled: Color of the icon when disabled. Can be a named color. Value is string.
  • style: Sets a style for the icon. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.
object
unselectedIconSettings for the appearance of the radio's icon when it is not selected.
object
radioStyleSets a style for the radio buttons. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous.object
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
Component Events​
