Version: 8.3
Perspective - File Upload
Perspective File Upload Component Icon
Component Palette Icon:
The File Upload component allows users to upload files to the Gateway or other locations from a Perspective session using a script action on the onFileReceived component event. For an example, see Download and Upload Files page.
The component has different appearances based on its width. When initially dragged onto your View, a Browse button will be visible and paired with "Drag files here" text. At smaller widths, the component defaults to a simple cloud icon and no text. This icon can be changed using the fileUploadIcon property settings.
Properties​
NameDescriptionProperty Type
enabled
New in 8.3.5
Determines whether or not the component is enabled. Note that the color and style enabled/disabled properties are dependent on this property state. Default is true.
value: boolean
maxUploadsThe maximum number of concurrent (simultaneous) uploads to allow. Default is 5.value: integer
supportedFileTypesAn array of string values, indicating what file types are allowed to be uploaded. Example values are pdf or txt.array
fileSizeLimitSpecifies the maximum size of each uploaded file, in megabytes (MB). Default is 10 MB. Note that values over 20 MB are not allowed, unless the max-file-size property in the web.xml configuration file is set to a higher limit, as the max-file-size property overrides this setting.value: integer
fileUploadIconDetermines the icon used when the File Upload component is small.
  • path: Shorthand path to the icon source. Format is library/iconName. The materials icon library is a the primary source for icons. Value is string.
  • color: Color of the placeholder icon, if it exists. Can be chosen from a color wheel, a color palette, or entered as an RGB or HSL value. See Color Selector for more information.
    • enabled:
      New in 8.3.5
      Color of the icon when the parent enabled property is set to true.
    • disabled:
      New in 8.3.5
      Color of the icon when the parent enabled property is set to false.
  • style: Sets a style for the icon.
object
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.
  • enabled:
    New in 8.3.5
    Style of the component when the parent enabled property is set to true.
  • disabled:
    New in 8.3.5
    Style of the component when the parent enabled property is set to false.
object
Scripting​
See the Perspective - File Upload Scripting page for the full list of scripting functions available for this component.
