Version: 8.3
Perspective - Text Field
Component Palette Icon:
The Text Field component is used for input of any single-line text. This component will accept any alpha-numeric input.
If you need a field that accepts multiple lines of text, see the Perspective - Text Area component. If you're looking for a numeric field, see the Perspective - Numeric Entry Field component.
User Interaction​
The Text Field component properties have impact on the way a user can interact with a table in the runtime.
InteractionGeneral
EnabledWhen the enabled property is set to true, a user can edit the text field in the runtime. The user must double click on the field or press enter in order to edit the field. When done, press enter or leave the field, and the text field becomes non-editable again. When the enabled property is set to false, it is not editable even when it receives input focus.
GeneralThe Text Field also supports the reject updates during edit feature. This feature ignores updates coming from property bindings while the component is being edited by a user.
Properties​
NameDescriptionProperty Type
textText to display.value: string
placeholderText displayed when Text Field is empty.value: string
enabledIf true, user is allowed to alter text.value: boolean
deferUpdatesWhen true, updates to props.text will be deferred until focus is lost or enter is pressed.value: boolean
rejectUpdatesWhileFocusedWhen true, props.text will not accept updates from external sources while focused.value: boolean
spellcheckWhen true, text containing potential spelling errors will be underlined in red while the text is being edited in a launched session. Be aware there may be some slight behavioral differences in spellcheck error detection depending on the session browser.value: boolean
stylesSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
Component Events​
Example​
This example shows the Text Field in two states: the top image is with text entered and the bottom image is without text entered.
PropertyValue
props.textLab Results from QA: Chem Analysis OK
props.placeholderSingle Line Entry
