Version: 8.3
Perspective - Report Viewer
Component Palette Icon:
The Report Viewer component allows embedding reports from the Reporting Module into a Perspective views. The Reporting Module must be installed to use the Report Viewer component. To configure the Report Viewer, you must first create a report and provide the Path of that report in the 'source' property of the component.
You can specify any parameters that you are using in the report as values under the params property, but the parameter names must match. The values specified will be used instead of the default report parameters.
Interface Elements​
IconNameDescription
ZoomControls the zoom level of the PDF view.
PagerDisplays the current page and allows the user to increment or decrement pages.
DownloadDownloads the report.
After clicking Download, the button is disabled until the user either saves the report or cancels the download.
PopoutOpens the report in a new window.
Properties​
NameDescriptionProperty Type
sourcePath of the report (case sensitive) from the Reporting Module that this component should display. For example, your Report source path might be: "Folder/ReportName". Right-click on the report in the Project Browser to Copy Path.value: string
paramsAn object that can be enhanced with report parameters to use in a report.object
pageThe current page number displayed with the report. This property is updated as the pages are viewed.value: numeric
pageCountA read-only property that provides the total number of pages in the report.value: numeric
zoomLevelA number representing the desired zoom level as a percentage of the report width. The Fit Panel option is simply 1 as opposed to a percentage value.value: numeric
allowDownloadIf set to 'true,' an icon will be added to the control bar at the bottom of the component that will download the report as a PDF file when clicked. The value of this property is always treated as "false" when the report viewer component is viewed from the iOS and Android Perspective Mobile apps.value: boolean
downloadFilenameA filename used for the report if downloaded. Filename will default to the name of the report if this property is left blank.value: string
allowOpenInTabIf set to 'true,' an icon will be added to the control bar at the bottom of the component that will open a temporary PDF file in a new tab. The value of this property is always treated as "false" when the report viewer component is viewed from Perspective Workstation, as well as the iOS and Android Perspective Mobile apps.value: boolean
controlStyleAn object containing CSS style properties that are applied to the control bar and controls across the bottom.
  • classes: Styles defined in the project to be applied to this component.
object
styleAn object containing CSS style properties that are applied to the background display of the component.object
Component Events​
Example​
Configuring the Report Viewer​
The Report Viewer component provides an easy way to view and print reports in a Perspective View. Let's configure the Report Viewer for a report.
note
This example requires that you already have a report created in your Gateway. You can learn more about creating reports here.
  1. Drag a Report Viewer component into a view.
  2. Enter the Path of the report you want to view in the 'source' property of the Property Editor. The data from your report will immediately load into the Report Viewer.
    info
    You can right-click on any report in the designer Project Browser to Copy the full Path of the report.
  3. Parameters added during report creation are provided as properties in the Report Viewer. Add them under the 'params' object. (The example below uses the EndDate and StartDate parameters). The parameter names must match exactly to the parameters in your Report Resource, and will override any default values set in the Report Resource.
