Perspective - Tag Browse Tree Scripting
This page details the various scripting, component, and extension functions available for Perspective's Tag Browse Tree component.
Component Events​
onNodeClick​
Fires whenever a node is clicked.
| Object Path | Type | Description |
| event.name | String | The name of the node that was clicked. |
| event.path | String | The Tag path of the node that was clicked. |
onNodeDoubleClick​
Fires whenever a node is double-clicked.
onNodeContextMenu​
Fires whenever a node is right-clicked.
Component Functions​
This component does not have component functions associated with it.
Extension Functions​
filterBrowseNode​
Description
- Called for each Tag before it is displayed in the Tag Browse Tree. Provides an opportunity to create a complex filter for the Tags in the Tag Browse Tree. filerBrowseNode is best used alongside the Tag Browse Tree's root.path property to specify where the filter should begin filtering. Return False to exclude the Tag from displayed results.
Parameters
- ComponentModelScriptWrapper.SafetyWrapper self - A reference to the component that is invoking this function.
- NodeBrowseInfo node - The Tag returned as type NodeBrowseInfo. See the Ignition JavaDocs for usage.
Return
- Boolean - The function must return either a True or False.
Example​
# This example will filter out any nodes (both Tags and folders included) that do not match the string Ramp.
if node.name == "Ramp":
return True
else:
return False
