Version: 8.1
system.tag.writeAsync
Asynchronously writes values to tags at specified paths. The script will not wait for the write operation to complete before moving on, but you can provide a callback function to run further code after the write has finished.
For a blocking tag write operation, see system.tag.writeBlocking.
Permission Type: Tag Editing
system.tag.writeAsync(tagPaths, values, [callback])
ListtagPathsA List of tag paths to write to. A tag property can be included in the path. If no property is specified in a tag path, the Value property is assumed.
ListvaluesThe values to write to the specified paths.
CallablecallbackA function that will be invoked after the write operation is complete. The function must take a single argument: a List of QualityCode objects corresponding to the results of the write operation. [optional]
Nothing
Example #1 - Write to Multiple Tags
paths = ["[default]Tag1", "[default]Folder/Tag2"]
values = [10, 10]
system.tag.writeAsync(paths, values)
Example #2 - Using a Callback Function
values = [10, 10]
def myCallback(asyncReturn):
for result in asyncReturn:
# Do something if a bad qualified value was returned
if not result.good:
print result
system.tag.writeAsync(paths, values, myCallback)
