Version: 8.1
system.tag.rename
Renames a single tag or folder.
Permission Type: Tag Editing
system.tag.rename(tag, newName, [collisionPolicy])
StringtagA path to the tag or folder to rename.
StringnewNameThe new name for the tag or folder.
StringcollisionPolicyThe action to take when a tag or folder with the same path and name is encountered. Defaults to Abort. [optional]. Possible values include:
  • a - Abort and throw an exception
  • o - Overwrite and replace existing tag's configuration
  • i - Ignore that item in the list.
QualityCode - A QualityCode object that contains the results of the rename operation.
Example #1 - Rename a Folder
old = "[default]folder/tag"
new = "noun_1" # Note that the new name should not include the full path or tag provider. Just the name suffices.
system.tag.rename(old, new)
