system.serial.readBytes
Descriptionβ
Read numberOfBytes bytes from a serial port.
Syntaxβ
system.serial.readBytes(port, numberOfBytes [, timeout])
Parametersβ
| String | port | The previously configured serial port to use. |
| int | numberOfBytes | The number of bytes to read. |
| int | timeout | Maximum amount of time, in milliseconds, to block before returning. Default is 5000. [optional] |
Returnsβ
List[Byte] - A list containing bytes read from the serial port.
Scopeβ
Code Exampleβ
Code Snippet
# This example will read a specified number of bytes from a port called "COM1".
port = "COM1"
system.serial.readBytes("COM1",2)
