Version: 8.1
system.serial.closeSerialPort
Closes a previously opened serial port. Returns without doing anything if the named serial port is not currently open. Will throw an exception if the port is open and cannot be closed.
system.serial.closeSerialPort(port)
StringportThe name of the serial port, e.g., "COM1" or "dev/ttyS0".
Nothing
Code Snippet - Using a Literal Value
# This example will close a port called "COM1".
system.serial.closeSerialPort("COM1")
Code Snippet - Using a Variable
# This example will close a port using a variable called port that has a value of "COM1"
port = "COM1"
