system.mongodb.updateMany
Project Library scripts will not provide hints for MongoDB system functions unless the Script Hint Scope is set to Gateway. See the Scripting in Ignition page for more details on scripting hints.
Description
Updates all documents in the collection that match the filter.
Client Permission Restrictions
Syntax
system.mongodb.updateMany(connector, collection, filter, updates, [options])
Parameters
| String | connector | The name of connector (case-insensitive). |
| String | collection | The name of collection (case-sensitive). |
| PyDictionary | filter | A PyDictionary for specifying matching key value pair criteria when querying a collection. |
| PyDictionary | List[PyDictionary] | updates |
| PyDictionary | options | A PyDictionary for including additional update configurations. [optional]. |
Returns
PyDictionary result - Result of update action formatted as a PyDictionary with keys ‘acknowledged’, ‘modifiedCount’, ‘matchedCount’, and ‘upsertedId’.
Scope
Gateway, Perspective Session
Importing Classes
You can import classes from system.mongodb.types like you would other Python classes:
Example
from system.mongodb.types import ObjectId
newObjectId = ObjectId.get()
You can also iterate those system.mongodb.types packages to see all available classes:
Example
for d in dir(system.mongodb.types):
print d
API Docs
MongoDB-specific data types come from the org.bson.types package of the Mongo Java Driver API. The library of classes available for import can be accessed at this link: Mongo Java Driver 3.6.0 API Docs for Package org.bson.types.
Types References
The following values can be referenced for the types parameter at system.mongodb.types:
Binary
Code
CodeWScope
CodeWithScope
Decimal128
INSTANCE
MaxKey
MinKey
ObjectId
Symbol
Timestamp
Code Examples
# Specify unique field values to locate specific document. Here we are locating documents with the field 'limit' equal to 9000.
filter = {"limit": 9000}
# Specify document fields to update for found BSON document(s). 'limits' is an existing field on the document.
updates = [
{"$set":
"limit": 10000
# Apply parameters for function call.
print system.mongodb.updateMany("MongoDB", "accounts", filter, updates)
