system.mongodb.deleteMany
New in 8.1.28
note
Project Library scripts will not provide hints for MongoDB system functions unless the Script Hint Scope is set to Gateway. See the Scripting in Ignition page for more details on scripting hints.
Description
Removes documents from the collection that match the filter.
Client Permission Restrictions
Syntax
system.mongodb.deleteMany(connector, collection, filter, [options])
Parameters
| String | connector | The name of connector (case-insensitive). |
| String | collection | The name of collection (case-sensitive). |
| PyDictionary | filter | A PyDictionary for specifying matching key value pair criteria when querying a collection. |
| PyDictionary | options | A PyDictionary for including additional delete configurations. [optional] |
Returns
PyDictionary result - Result of delete action formatted as a PyDictionary with keys ‘acknowledged’ and ‘deleteCount’.
Scope
Gateway, Perspective Session
Code Examples
Example #1
# Specify unique field values to locate specific documents.
filter = {"qualityControlProcess":"V020"}
# Apply parameters for function call.
print system.mongodb.deleteMany("MongoDB", "data", filter)
