system.device.setDeviceEnabled
Descriptionβ
Enables/disables a device in Ignition.
Permission Type: Device Management
Syntaxβ
system.device.setDeviceEnabled(deviceName, enabled)
Parametersβ
| String | deviceName | The name of the device in Ignition. |
| Boolean | enabled | Specifies whether the device connection will be set to enabled or disabled state. |
Returnsβ
Nothing
Scopeβ
Code Examplesβ
Code Snippet
# Example 1: Enable a device
system.device.setDeviceEnabled("CLX", 1)
Code Snippet
# Example 2: Disable a device
system.device.setDeviceEnabled("CLX", 0)
