Version: 8.3
system.device.setDeviceEnabled
Enables/disables a device in Ignition.
Permission Type: Device Management
system.device.setDeviceEnabled(deviceName, enabled)
StringdeviceNameThe name of the device in Ignition.
BooleanenabledSpecifies whether the device connection will be set to enabled or disabled state.
Nothing
Code Snippet
# Example 1: Enable a device
system.device.setDeviceEnabled("CLX", 1)
Code Snippet
# Example 2: Disable a device
system.device.setDeviceEnabled("CLX", 0)
