system.date.add*
Descriptionβ
This function is a set of functions that include:
| Function | Description |
| system.date.addMillis | Add or subtract an amount of milliseconds to a given date and time. |
| system.date.addSeconds | Add or subtract an amount of seconds to a given date and time. |
| system.date.addMinutes | Add or subtract an amount of minutes to a given date and time. |
| system.date.addHours | Add or subtract an amount of hours to a given date and time. |
| system.date.addDays | Add or subtract an amount of days to a given date and time. |
| system.date.addWeeks | Add or subtract an amount of weeks to a given date and time. |
| system.date.addMonths | Add or subtract an amount of months to a given date and time. This function is unique since each month can have a variable number of days. For example, if the date passed in is March 31st, and we add one month, April does not have a 31st day, so the returned date will be the proper number of months rounded down to the closest available day, in this case April 30th. |
| system.date.addYears | Add or subtract an amount of years to a given date and time. |
Syntaxβ
system.date.add*(date, value)
Parametersβ
| Date | date | The starting date. |
| Integer | value | The number of units to add or subtract. Positive values will add specified units, and negative values will subtracts specified units. |
Returnsβ
Date - A new date object offset by the integer passed to the function.
Scopeβ
Code Examplesβ
Example #1
# This example adds two days to the date passed in.
today = system.date.now()
twoDaysFromToday = system.date.addDays(today, 2)
Example #2
# This example subtracts 20 minutes from the date object created.
# Notice that although our original date starts at midnight,
# so subtracting 20 minutes puts it at the previous day.
# Set your date as Thu Jun 25 00:00:00 PDT 2020
date = system.date.getDate(2020, 5, 25)
# Print the date adjustment of 20 minutes prior: Wed Jun 24 23:40:00 PDT 2020
print system.date.addMinutes(date, -20)
Example #3
# This example works as a property change script of a Vision Calendar component.
# It sets a second Calendar component two weeks in advance of the first Calendar component.
if event.propertyName == "date":
date = event.newValue
event.source.parent.getComponent('End Date Calendar').date = system.date.addWeeks(date, 2)
