system.date.*Between
Descriptionβ
This function is a set of functions that include:
| Function | Description |
| system.date.millisBetween | Calculates the number of whole milliseconds between two dates. |
| system.date.secondsBetween | Calculates the number of whole seconds between two dates. |
| system.date.minutesBetween | Calculates the number of whole minutes between two dates. |
| system.date.hoursBetween | Calculates the number of whole hours between two dates. |
| system.date.daysBetween | Calculates the number of whole days between two dates. Daylight savings changes are taken into account. |
| system.date.weeksBetween | Calculates the number of whole weeks between two dates. |
| system.date.monthsBetween | Calculates the number of whole months between two dates. Daylight savings changes are taken into account. |
| system.date.yearsBetween | Calculates the number of whole years between two dates. Daylight savings changes are taken into account. |
Order matters when passing in the two dates required by this function. system.date.*Between will subtract the first date from the second date, meaning if date 2 is further in time than date 1, then a positive amount of time has passed. If date 2 is backwards in time from date 1, then a negative amount of time has passed.
Syntaxβ
system.date.*Between(date_1, date_2)
Parametersβ
| Date | date_1 | The first date to use. |
| Date | date_2 | The second date to use. |
Returnsβ
Integer - An integer that is representative of the difference between two dates.
Scopeβ
Code Examplesβ
Example #1
# This example would grab the current time, and add 119 minutes to it, then calculate the number
# of hours between the two dates.
first = system.date.now()
second = system.date.addMinutes(first, 119)
print system.date.hoursBetween(first, second) # This would print 1 since it is only 1 whole hour.
Example #2
# This example would create two date objects, one on the 28th of May,
# and one on the 22nd of April, both in 2020. Because the second date is
# before the first date, a negative number will be returned.
first = system.date.getDate(2020, 4, 28)
second = system.date.getDate(2020, 3, 22)
print system.date.daysBetween(first, second) # This will print -36
Example #3
# This example can be placed on the action performed event of a button.
# It will then grab the week difference of two calendar components,
# and enter the value returned into a numeric text field.
first = event.source.parent.getComponent('Start Date Calendar').date
second = event.source.parent.getComponent('End Date Calendar').date
event.source.parent.getComponent('Numeric Text Field').intValue = system.date.weeksBetween(first, second)
