Version: 8.3
system.date.add*
This function is a set of functions that include:
FunctionDescription
system.date.addMillisAdd or subtract an amount of milliseconds to a given date and time.
system.date.addSecondsAdd or subtract an amount of seconds to a given date and time.
system.date.addMinutesAdd or subtract an amount of minutes to a given date and time.
system.date.addHoursAdd or subtract an amount of hours to a given date and time.
system.date.addDaysAdd or subtract an amount of days to a given date and time.
system.date.addWeeksAdd or subtract an amount of weeks to a given date and time.
system.date.addMonthsAdd or subtract an amount of months to a given date and time. This function is unique since each month can have a variable number of days. For example, if the date passed in is March 31st, and we add one month, April does not have a 31st day, so the returned date will be the proper number of months rounded down to the closest available day, in this case April 30th.
system.date.addYearsAdd or subtract an amount of years to a given date and time.
system.date.add*(date, value)
DatedateThe starting date.
IntegervalueThe number of units to add or subtract. Positive values will add specified units, and negative values will subtracts specified units.
Date - A new date object offset by the integer passed to the function.
Example #1
# This example adds two days to the date passed in.
today = system.date.now()
twoDaysFromToday = system.date.addDays(today, 2)
Example #2
# This example subtracts 20 minutes from the date object created.
# Notice that although our original date starts at midnight,
# so subtracting 20 minutes puts it at the previous day.
# Set your date as Thu Jun 25 00:00:00 PDT 2026
date = system.date.getDate(2026, 5, 25)
# Print the date adjustment of 20 minutes prior: Wed Jun 24 23:40:00 PDT 2026
print system.date.addMinutes(date, -20)
Example #3
# This example works as a property change script of a Vision Calendar component.
# It sets a second Calendar component two weeks in advance of the first Calendar component.
if event.propertyName == "date":
date = event.newValue
event.source.parent.getComponent('End Date Calendar').date = system.date.addWeeks(date, 2)
