Version: 8.1
Perspective - Signature Pad Scripting
This page details the various scripting, component, and extension functions available for Perspective's Signature Pad component.
Component Events​
onSignatureSubmitted​
Event is fired after the Gateway has received a submitted signature.
note
This component event is designed to be used in tandem with a run action script. Within the script action, special properties and methods are available on the event object, which is passed to the script action as a parameter.
event.signature​
  • Object Path
    • event.signature
  • Type
    • String
  • Description
    • Base64-encoded PNG DataURL of the submitted signature.
event.signatureFile.name​
  • Object Path
    • event.signatureFile.name
  • Type
    • String
  • Description
    • A name for the signature file.
event.signatureFile.size​
  • Object Path
    • event.signatureFile.size
  • Type
    • Integer
  • Description
    • The size of the signature image file in bytes.
event.signatureFile.copyTo(filePath)​
  • Object Path
    • event.signatureFile.copyTo()
  • Description
    • Saves the uploaded signature file at a location accessible to the Gateway.
  • Parameters
    • String filePath - The path to where the file should be saved on the Gateway.
  • Return
    • None
event.signatureFile.getBytes()​
  • Object Path
    • event.signatureFile.getBytes()
  • Description
    • Returns a bytearray of the image, allowing the signature file to be saved from the session (with system.perspective.download()).
  • Parameters
    • None
  • Return
    • byteArray - The raw data of the incoming file.
event.signatureFile.getString()​
  • Object Path
    • event.file.getString()
  • Description
    • Fetches the incoming file data and attempts to parse it as a string via UTF-8 (Eight-bit UCS Transformation Format) encoding. Defaults to UTF-8 (super common), but can use other character sets. Passed as a string, for example getString("UTF_16BE).
  • Parameters
    • None
  • Return
    • byteArray - The raw data of the incoming signature file.
onSignatureCleared​
This event is fired when the Gateway has received a signal that the signature has been cleared.
note
event​
  • Object Path
    • event
  • Type
    • Null
  • Description
    • An empty event object.
Component Functions​
.clearSignature()​
  • Description
    • Clears the current signature on the component
  • Parameters
    • None
  • Return
    • Nothing
.submitSignature()​
  • Description
    • Submits the signature, triggering the onSignatureSubmitted component event.
  • Parameters
    • None
  • Return
    • Nothing
Extension Functions​
