Version: 8.1
Perspective - Password Field
Component Palette Icon:
The Password Field component is similar to a Text Field component. It allows users to enter their password text. When the Password field is empty, you can create a placeholder that informs user to "Login". You can also enable the "allowReveal" property to allow users to view their password entry.
Properties​
NameDescriptionProperty Type
textPassword text.value: string
placeholderText displayed when password text is empty.value: string
enabledWhether the user can alter the password text. Default is true.
Note: If the component is disabled, scripts can still run on the component. For example, if you add a script action to a System Event, such as an onStartup event, the script will fire when the page is loaded. Events that require user interaction, such as onClick events, will not fire with the exception of Pointer Events.
value: boolean
allowRevealWhether the user can temporarily remove the password mask, revealing the password.value: boolean
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
Component Events​
Example​
PropertyValue
props.placeholderEnter Password
props.borderStylesolid
props.borderColor#D90000
props.borderWidth3px
props.fontSize14px
propsfontWeightbold
