Perspective - Text Area
Component Palette Icon:
Suitable for multi-line text display and editing. Will scroll vertically on demand. Horizontal scroll is determined by the "wrap" property.
Properties​
Name | Description | Property Type |
text | Text to display. | value: string |
placeholder | Text displayed when Text Area is empty. | value: string |
enabled | If true, user is allowed to alter text. | value: boolean |
deferUpdates | When true, updates to props.text will be deferred until focus is lost or enter is pressed. | value: boolean |
rejectUpdatesWhileFocused | When true, props.text will not accept updates from external sources while focused. | value: boolean |
resize | Sets whether text is resizable, and if so, in which direction: none, both, horizontal, or vertical. | value: string |
wrap | Specifies how to wrap text: hard, soft, or off. (Soft wrap is the break resulting from a line wrap or word wrap. Hard wrap is an intentional break, which moves text to the next line, or creates a new paragraph). | value: string |
style | Sets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
spellcheck | New in 8.1.27 When true, text containing potential spelling errors will be underlined in red while the text is being edited in a launched session. Be aware there may be some slight behavioral differences in spellcheck error detection depending on the session browser. | value: boolean |
Component Events​
Example​
This example shows the Text Area in two states: the top image is with text entered and the bottom image is without text entered.
Property | Value |
props.text | Data Point 01: xy4, zBeta 3 Data Point 02: xy12, zBeta 45 Notes: Example of how a longer sentence can wrap (or not) around to the next line. Enter was pressed between each of these three lines. |
props.placeholder | Lab Data Entry |
props.wrap | off |
