Version: 8.1
Perspective - Slider
Component Palette Icon:
The Slider component lets the user drag an indicator along a scale to choose a value in a range. Enable the "show" and "interval" properties under "labels" to visually display the values within a range. The slider can be configured to orient horizontally or vertically with the "orientation" property.
Properties​
NameDescriptionProperty Type
valueValue represented by slider handle. Current value of the slider.value: numeric
minThe minimum value for the slider scale: all the way left or down.value: numeric
maxThe maximum value for the slider scale: all the way right or up.value: numeric
orientationSpecifies whether the slider track is aligned vertically or horizontally.value: boolean
stepIntervals along track at which a value may be set. Specifies the size of increments between values of the slider.
Note: This does not force the value into that step size. Setting the slider value manually or through a binding will cause it to show the actual value.
value: numeric
labelsLabel settings along the track.
  • show: If true, displays labels at periodic values along track. Value is boolean.
  • interval: Interval at which to display periodic labels along track. Value is numeric.
object
enabledWhether slider interaction is currently active.
Note: If the component is disabled, scripts can still run on the component. For example, if you add a script action to the onClick event, the script will fire when the user clicks on the Slider.
value: boolean
handleColorColor of slider handle. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector Reference.color
trackColorColor of slider track. See Color Selector Reference.color
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
Component Events​
Example​
PropertyValue
props.value65
props.orientationvertical
props.step5
props.labels.showtrue
props.labels.interval10
props.handleColor#8AFF8A
props.trackColor#CCFFFF
