Version: 8.1
Perspective - DateTime Input
Component Palette Icon:
A DateTime Input is an easy way to select a date from a popup calendar. Similar to the DateTime Picker component, it takes up much less real estate on the screen. Configure the date and time format in the Property Editor using the 'formattedValue' property.
New in 8.1.2
The DateTime Input component has two pre-configured variants:
  • Date and Time - Opens a calendar from which users can select a date and time.
  • Time - Enables users to set a time using the up and down arrows on the component.
Properties​
NameDescriptionProperty Type
valueCurrent date/time as a Date object or timestamp in milliseconds.value: string
formattedValueDate and time in configured format.value: string
inputPropsSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous.object
modalStyleStyle applied to the Date picker modal (popup). Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
pickerTypeWhether to display and enable picker for date only, time only, or both date and time.value: string
minDateMinimum date/time as a Date object or timestamp in milliseconds. If null, the minimum date is 10 years in the past from today.value: string
maxDateMaximum date/time as a Date object or timestamp in milliseconds. If null, the maximum date is 10 years in the future from today.value: string
formatTemplate for formatting date display - must be valid moment.js format, e.g., 'MM/DD/YYYY h:mm a'.value: string
enabled'False' will disable any interaction with the calendar.
Note: If the component is disabled, scripts can still run on the component. For example, if you add a script action to a System Event, such as an onStartup event, the script will fire when the page is loaded. Events that require user interaction, such as onClick events, will not fire with the exception of Pointer Events.
value: boolean
placeholderText for input field to display when no date/time is selected.value: boolean
localeCode for localization of language and formatting. Use the dropdown to select language.value: string
dismissOnSelectDetermines if the date picker should be dismissed when a date is selected.value: boolean
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
Component Events​
Example​
PropertyValueStyle Category
props.pickerTypedateN/A
props.formatMM/DD/YYYYN/A
props.style.borderStylesolidborder
props.style.borderColor#00AC00border
props.style.borderWidth2pxborder
