Version: 8.1
Perspective - Toggle Switch
Component Palette Icon:
The Toggle Switch represents a bit: on (selected) or off (not selected). By default, when the switch is selected the color is blue. It is gray when it is not selected. Logically, this component is very similar to the Checkbox component.
New in 8.1.2
The Toggle Switch component has three pre-configured variants:
  • No Text - Default layout with no text.
  • Text Right - Layout with text on the right of the Toggle Switch.
  • Text Left - Layout with text on the left of the Toggle Switch.
Properties​
NameDescriptionProperty Type
selectedThe selected state of the Toggle Switch.value: boolean
labelSettings for the label for the Toggle Switch.
  • text: Text for the Toggle Switch.
      New in 8.1.2
      Text can also be entered directly by deep selecting the Toggle Switch component, which enables inline editing. Changes are immediately reflected in the text property field. Value is string.
  • position: Text position relative to the Toggle Switch: right or left. Value is boolean.
  • style: Modify text style using the style properties. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.
object
colorColor settings for the Toggle Switch when it is selected and unselected.
  • selected: Color of the Toggle Switch when selected (on). Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector.
  • unselected: Color of the Toggle Switch when unselected (off). See Color Selector.
object
enabledWhether the user should be allowed to alter the Toggle Switch's selected state. Default is true.
Note: If the component is disabled, scripts can still run on the component. For example, if you add a script action to the onClick event, the script will fire when the user clicks on the Toggle Switch.
value: boolean
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
Component Events​
Example​
Image above shows both selected and deselected positions for the following properties.
PropertyValue
props.label.textOff / On
props.label.positionleft
props.color.selected#FF0000
props.color.unselected#8AFF8A
