Version: 8.1
Perspective - Barcode Scanner Input
Component Palette Icon:
The Barcode Scanner Input component awaits for input from a barcode scanner. The component was designed for keyboard wedge scanners, as the component provides dedicated prefix and suffix properties to define scanner input. As such, it can be useful to think of the Barcode Scanner Input component as a specialized text field that does not require focus, and uses characters to decide when to accept and reject text input.
The scanner component is continuously listening, waiting for either the prefix and suffix characters to be entered, or the regex pattern to find a match. Once triggered, the component will load the scanned barcode string (excluding the prefix and suffix) into the data property for processing. The regex property can be used to extract specific fields from a scan, or validate data from the scan.
Properties​
NameDescriptionProperty Type
prefixString value that mark the start of the barcode scan capture. If a value is provided to this property, then the regex property will be ignored.value: string
suffixString value that marks the end of the barcode scan capture. If a value is provided to this property, then the regex property will be ignored.value: string
regexRegex describing the format of scans. The first capture will be used as barcode. When used, this property will pull out the first group of any regex provided. Note that this setting uses Javascript regex, as opposed to other flavors of regex. If either a prefix or suffix value is specified with a non-empty string, then this property will be ignored.object
windowLength of buffer to monitor for regex match.value: numeric
captureMode
New in 8.1.16
Indicates which key event the component will listen for to start the barcode scan capture. Values include keypress, keyup, and keydown. Default value is keypress.
value: string
dataBarcode scans returned from scanner.array
dataStyleSets a style for data returned to this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.
Styles can can be set on the component before a value is scanned.
object
Component Events​
