Reverse Proxy Considerations
While a forward proxy proxies on behalf of clients (or requesting hosts), a reverse proxy proxies on behalf of servers. There are many possible use cases for placing Perspective behind a reverse proxy:
- Control what resources the user is able to access
- Direct traffic to a portion of the web server
- Limit which projects are accessible to users via subdomains
- Define an SSL certificate on the reverse proxy
Defining SSL on a Perspective Reverse Proxyβ
The following example demonstrates how to define SSL on a Perspective Reverse Proxy. For this, we will use NGINX to define an SSL certificate and key. NGINX is a popular choice for reverse proxies, though other open source servers such as Varnish, Apache, and Traefik provide similar functionality.
Installationβ
Install NGINX or NGINX Plus following the relevant installation instructions. Obtain a Signed Security Certificate (SSL) and place the SSL certificate and key in the directory where you installed NGINX under etc/nginx/ssl/.
Configuring NGINXβ
In this example, we will create an nginx.conf file that specifies the configuration of our server. This section details the modules and properties that are required to configure Perspective behind a reverse proxy; for a more general overview of a proxy server configuration, see the NGINX Admin Guide.
Required NGINX Modulesβ
| Module | Documentation |
| ngx_http_core_module | https://nginx.org/en/docs/http/ngx_http_core_module.html |
| ngx_http_proxy_module | https://nginx.org/en/docs/http/ngx_http_proxy_module.html |
| ngx_http_ssl_module | https://nginx.org/en/docs/http/ngx_http_ssl_module.html |
Websocket Proxyingβ
For compatibility with Perspective's Websocket connections, we change the HTTP version to 1.1. In order to pass hop-by-hop headers from the client to the proxied server, the "Upgrade" and "Connection" headers must be passed explicitly in the configuration file:
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
Custom Headersβ
In cases where a reverse proxy or other middleware is located between the Gateway and a running Perspective session, the proxy server will need to whitelist custom headers. Doing so ensures that the proxy allows requests from the session to pass through to the Gateway.
- client-timezone
- device-id
- device-type
- version-code
- perspective-session-id
- designer-session-id
To allow requests with custom headers, you will need to enable proxy_pass_request_headers in your configuration file.
location / {
proxy_pass https://localhost:8043/data/perspective/client/demo/;
proxy_pass_request_headers on;
Additional Location Contextsβ
Perspective sessions require resources within several folders that must be defined as additional location contexts within the configuration file. The following additional locations are required to enable the Perspective session to run the reverse proxy.
server {
location ^~ /data/ {
location ^~ /system/ {
location ^~ /res/ {
location ^~ /idp/ {
location ^~ /.well-known/ {
Example Configurationβ
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name demo.xxx.com;
underscores_in_headers on;
# Specify the paths to your SSL certificate and key:
ssl_certificate /etc/nginx/ssl/reverse_proxy.crt;
ssl_certificate_key /etc/nginx/ssl/reverse_proxy.key;
# The next few location contexts define how to process resources required by the Perspective session.
# If the longest matching prefix location has the β^~β modifier then regular expressions are not checked.
proxy_pass https://localhost:8043/data/;
proxy_set_header Connection 'upgrade';
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
proxy_pass https://localhost:8043/system/;
location ^~ /res/ {
proxy_pass https://localhost:8043/res/;
location ^~ /idp/ {
proxy_pass https://localhost:8043/idp/;
proxy_pass https://localhost:8043/.well-known/;
# Here we are setting the protocol type, address, port, and uri (optional)
# that will be the destination of our proxied server:
location / {
Support for Proxy Forwarding of Remote HTTP Client Detailsβ
A Use Proxy Forwarded Headers setting is available on the Gateway Network > Network Settings > Web Server page under the HTTP Settings section. It allows the Gateway to use a reverse proxyβs HTTP client details instead of the reverse-proxy itself.
