Version: 8.1
Perspective - Split Container Scripting
This page details the various scripting, component, and extension functions available for Perspective's Split Container component.
Component Events​
onMinBoundReached​
This event is fired when the split reaches the minimum bound on the container. For example, when the split bar's position reaches 0 px or 0% of the container's width.
note
This component event is designed to be used in tandem with a script runAction. Within the script action, special properties and methods are available on the event object, which is passed to the script action as a parameter.
onMaxBoundReached​
This event is fired when the split reaches the maximum bound on the container. For example, when the split bar's position reaches 100% of the container's width.
note
Component Functions​
.getChildren()​
  • Description
    • Returns an ArrayList, which contains references to all components inside of the container.
  • Parameters
    • None
  • Return
    • Array List - An ArrayList of components in the container. The resulting ArrayList can be iterated over via a for-loop.
Extension Functions​
