Perspective - Split Container Scripting
This page details the various scripting, component, and extension functions available for Perspective's Split Container component.
Component Eventsβ
onMinBoundReachedβ
This event is fired when the split reaches the minimum bound on the container. For example, when the split bar's position reaches 0 px or 0% of the container's width.
This component event is designed to be used in tandem with a script runAction. Within the script action, special properties and methods are available on the event object, which is passed to the script action as a parameter.
onMaxBoundReachedβ
This event is fired when the split reaches the maximum bound on the container. For example, when the split bar's position reaches 100% of the container's width.
Component Functionsβ
.getChildren()β
- Description
- Returns an ArrayList, which contains references to all components inside of the container.
- Parameters
- None
- Return
- Array List - An ArrayList of components in the container. The resulting ArrayList can be iterated over via a for-loop.
Extension Functionsβ
