Version: 8.1
system.secsgem.toTreeDataset
Changes an existing dataset, as returned by the system.secsgem.toDataSet function, to make it usable for the Tree View component.
system.secsgem.toTreeDataset(dataset)
DatasetdatasetA DataSet containing a SECS message. Note that this parameter cannot take a JSON message, so the object returned by system.secsgem.getResponse must first be processed by system.secsgem.toDataSet.
Dataset - A dataset containing a SECS message with the following columns, as suited for Vision's tree view component: "path", "text", "icon", "background", "foreground", "tooltip", "border", "selectedText", "selectedIcon", "selectedBackground", "selectedForeground", "selectedTooltip", "selectedBorder"
Code Example​
Code Snippet
# Assuming the variable named "message" contains a SECS message, we will first convert it to a Dataset.
dataset = system.secsgem.toDataset(message)
# The initial dataset generated by toDataSet will not work with the Tree View component, so we'll modify it...
dataset = system.secsgem.toTreeDataset(dataset)
# ...and now pass the dataset into the Tree View component's data property.
event.source.parent.getComponent('Tree View').data = dataset
