system.secsgem.startSimEventRun
Descriptionβ
Starts a configured simulator event run in the Gateway. Note, that this function only works with the simulators that come included with the SECS/GEM module.
The function will throw an exception if the specified Event Run cannot be started.
Permission Type: SECS/GEM Management
Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when called in the Gateway scope.
Syntaxβ
system.secsgem.startSimEventRun(simulatorName, eventRunName)
Parametersβ
| String | simulatorName | The simulator that holds the configured event run. Will throw an exception if the specified simulator can't be found. |
| String | eventRunName | The event run to start. Will throw an exception if the specified simulator can't be found. |
Returnsβ
Nothing
Scopeβ
Vision Client
Code Examplesβ
Code Snippet
# This examples requires that the Gateway has a simulator named "simulator1", and
# an Event Run in that same simulator named "myEventRun".
mySimulator = "simulator1"
eventRun = "myEventRun"
system.secsgem.startSimEventRun(mySimulator, eventRun)
