system.iec61850.readFile
New in 8.1.25
Descriptionβ
This function downloads remote files from the configured IEC 61850 device to an identified local path.
Syntaxβ
system.iec61850.readFile(deviceName, remoteFilePath, localFilePath)
Parametersβ
| String | deviceName | The name of the configured IEC 61850 device. |
| String | remoteFilePath | The remote file path on the server of the file to read. |
| String | localFilePath | The local file path on client to store the file contents. |
Returnsβ
No return value.
Scopeβ
Gateway, Perspective Session
Code Examplesβ
Example #1
# This example reads the file contents from device remote file path.
# The read file is stored in the local file path.
# Ignition 61850 Device Name
device_name = 'IEC61850'
# File name you wish to read for the 61850 Device
file_name = 'COMFEDE.ced'
# Full Path where the file will be read from the 61850 device
file_path = '/{0}'.format(file_name)
# Full Path where to store your file on your Ignition Gateway
local_path = '/usr/local/bin/ignition/COMFEDE/{0}'.format(file_name)
system.iec61850.readFile(device_name, file_path, local_path)
