Version: 8.3
system.iec61850.readFile
This function downloads remote files from the configured IEC 61850 device to an identified local path.
system.iec61850.readFile(deviceName, remoteFilePath, localFilePath)
StringdeviceNameThe name of the configured IEC 61850 device.
StringremoteFilePathThe remote file path on the server of the file to read.
StringlocalFilePathThe local file path on client to store the file contents.
No return value.
Gateway, Perspective Session
Example #1
# This example reads the file contents from device remote file path.
# The read file is stored in the local file path.
# Ignition 61850 Device Name
device_name = 'IEC61850'
# File name you wish to read for the 61850 Device
file_name = 'COMFEDE.ced'
# Full Path where the file will be read from the 61850 device
file_path = '/{0}'.format(file_name)
# Full Path where to store your file on your Ignition Gateway
local_path = '/usr/local/bin/ignition/COMFEDE/{0}'.format(file_name)
system.iec61850.readFile(device_name, file_path, local_path)
