system.eam.queryAgentStatus
Descriptionβ
Returns the current state of the matching agents. This function can only be called from the Controller.
Syntaxβ
system.eam.queryAgentStatus(groupIds, agentIds, isConnected)
Parametersβ
| List | groupIds | A list of groups to restrict the results to. If not specified, all groups will be included. |
| List | agentIds | A list of agent names to restrict the results to. If not specified, all agents will be allowed. |
| Boolean | isConnected | If True, only returns agents that are currently connected. If False, only agents that are considered down will be returned, and if not specified, all agents will be returned. |
Returnsβ
Dataset - A dataset with columns AgentName, NodeRole, AgentGroup, LastCommunication, IsConnected, IsRunning, RunningState, RunningStateInt, LicenseKey, and Version, where each row is a new agent.
note
Possible values for RunningState and RunningStateInt are: 0 = Disconnected, 1 = Running, 2 = Warned, 3 = Errored
Scopeβ
Code Examplesβ
Example #1 - Querying Agent Status Information
# This script will loop through each row of the dataset and grab out every value from that row and assign it to a matching variable. Those variables can then be used in some way.
results=system.eam.queryAgentStatus()
for row in range(results.rowCount):
agentName=results.getValueAt(row, "AgentName")
nodeRole=results.getValueAt(row, "NodeRole")
agentGroup=results.getValueAt(row, "AgentGroup")
lastComm=results.getValueAt(row, "LastCommunication")
isConnected=results.getValueAt(row, "IsConnected")
isRunning=results.getValueAt(row, "IsRunning")
runningState=results.getValueAt(row, "RunningState")
runningStateInt=results.getValueAt(row, "RunningStateInt")
licenseKey=results.getValueAt(row, "LicenseKey")
platformVersion=results.getValueAt(row, "Version")
# Can include some code here to use the variables in some way for each row like printing each variable to the console.
Example #2 - Querying Agent Status Information
# This script will grab status information from agents called Agent1, Agent2, Agent3, and will then place the data into a table on the same window.
results=system.eam.queryAgentStatus(agentIds=["Agent1", "Agent2", "Agent3"])
event.source.parent.getComponent('Table').data = results
