system.eam.queryAgentStatus
Descriptionβ
Returns the current state of the matching agents. This function can only be called from the Controller. If called from an Agent, this function will return an exception.
Syntaxβ
system.eam.queryAgentStatus(groupIds, agentIds, isConnected)
Parametersβ
| List | groupIds | A list of groups to restrict the results to. If not specified, all groups will be included. |
| List | agentIds | A list of agent names to restrict the results to. If not specified, all agents will be allowed. |
| Boolean | isConnected | If True, only returns agents that are currently connected. If False, only agents that are considered down will be returned, and if not specified, all agents will be returned. |
Returnsβ
Dataset - A dataset with columns AgentName, NodeRole, AgentGroup, LastCommunication, IsConnected, IsRunning, RunningState, RunningStateInt, LicenseKey, and Version, where each row is a new agent.
note
Possible values for RunningState and RunningStateInt are: 0 = Disconnected, 1 = Running, 2 = Warned, 3 = Errored
Scopeβ
Code Examplesβ
Example #1 - Querying Agent Status Information
# This script will loop through each row of the dataset and grab out every value from that row and assign it to a matching variable. Those variables can then be used in some way.
results=system.eam.queryAgentStatus()
for row in range(results.rowCount):
agentName=results.getValueAt(row, "AgentName")
nodeRole=results.getValueAt(row, "NodeRole")
agentGroup=results.getValueAt(row, "AgentGroup")
lastComm=results.getValueAt(row, "LastCommunication")
isConnected=results.getValueAt(row, "IsConnected")
isRunning=results.getValueAt(row, "IsRunning")
runningState=results.getValueAt(row, "RunningState")
runningStateInt=results.getValueAt(row, "RunningStateInt")
licenseKey=results.getValueAt(row, "LicenseKey")
platformVersion=results.getValueAt(row, "Version")
# Can include some code here to use the variables in some way for each row like printing each variable to the console.
Example #2 - Querying Agent Status Information
# This script will grab status information from agents called Agent1, Agent2, Agent3, and will then place the data into a table on the same window.
results=system.eam.queryAgentStatus(agentIds=["Agent1", "Agent2", "Agent3"])
event.source.parent.getComponent('Table').data = results
