Version: 8.1
system.bacnet.readRaw
New in 8.1.18
Read from any BACnet object not explicitly supported by the BACnet driver.
note
To use this function, the BACnet driver must be installed.
caution
Please use caution when interacting directly with any BACnet device, as writing to an object may have unintended consequences and could result in data loss.
system.bacnet.readRaw(deviceName, objectType, objectId, propertyId, [propertyArrayIndex])
StringdeviceNameThe name of the configured BACnet/IP device instance to read from.
ObjectTypeobjectTypeThe numeric id of the objectType of the object instance being read from. See the objectType Reference below.
IntegerobjectIdThe object instance number to read.
PropertyIdentifierpropertyIdThe PropertyIdentifier of the object instance being read. See the propertyId Reference below.
IntegerpropertyArrayIndex[optional] The array index of the property to read from. This parameter is optional and should not be used when reading from the entire array or if the property is not an array.
Nothing
Gateway
Importing Classes​
You can import classes from system.bacnet.* like you would other Python classes:
Example
from system.bacnet.enumerated import ObjectType
from system.bacnet.enumerated import PropertyIdentifier
ot = ObjectType.calendar
pid = PropertyIdentifier.dateList
You can also iterate those system.bacnet.* packages to see all available classes:
Example
for d in dir(system.bacnet.constructed):
print d
API Docs​
BACnet4j Library of all classes available for import can be accessed at this link: BACnet4j Library 6.0.1 API Docs
References​
objectType Reference​
Values for the objectType parameter can be referenced at system.bacnet.enumerated.ObjectType.*
objectType Reference List
  • analogInput
  • analogOutput
  • analogValue
  • binaryInput
  • binaryOutput
  • binaryValue
  • calendar
  • command
  • device
  • eventEnrollment
  • file
  • group
  • loop
  • multiStateInput
  • multiStateOutput
  • notificationClass
  • program
  • schedule
  • averaging
  • multiStateValue
  • trendLog
  • lifeSafetyPoint
  • lifeSafetyZone
  • accumulator
  • pulseConverter
  • eventLog
  • globalGroup
  • trendLogMultiple
  • loadControl
  • structuredView
  • accessDoor
  • timer
  • accessCredential
  • accessPoint
  • accessRights
  • accessUser
  • accessZone
  • credentialDataInput
  • networkSecurity
  • bitstringValue
  • characterstringValue
  • datePatternValue
  • dateValue
  • datetimePatternValue
  • datetimeValue
  • integerValue
  • largeAnalogValue
  • octetstringValue
  • positiveIntegerValue
  • timePatternValue
  • timeValue
  • notificationForwarder
  • alertEnrollment
  • channel
  • lightingOutput
  • binaryLightingOutput
  • networkPort
  • elevatorGroup
  • escalator
  • lift
propertyId Reference​
Values for the propertyId parameter can be referenced at system.bacnet.enumerated.PropertyIdentifier.*
propertyId Reference List
  • ackedTransitions
  • ackRequired
  • action
  • actionText
  • activeText
  • activeVtSessions
  • alarmValue
  • alarmValues
  • all
  • allWritesSuccessful
  • apduSegmentTimeout
  • apduTimeout
  • applicationSoftwareVersion
  • archive
  • bias
  • changeOfStateCount
  • changeOfStateTime
  • notificationClass
  • controlledVariableReference
  • controlledVariableUnits
  • controlledVariableValue
  • covIncrement
  • dateList
  • daylightSavingsStatus
  • deadband
  • derivativeConstant
  • derivativeConstantUnits
  • description
  • descriptionOfHalt
  • deviceAddressBinding
  • deviceType
  • effectivePeriod
  • elapsedActiveTime
  • errorLimit
  • eventEnable
  • eventState
  • eventType
  • exceptionSchedule
  • faultValues
  • feedbackValue
  • fileAccessMethod
  • fileSize
  • fileType
  • firmwareRevision
  • highLimit
  • inactiveText
  • inProcess
  • instanceOf
  • integralConstant
  • integralConstantUnits
  • limitEnable
  • listOfGroupMembers
  • listOfObjectPropertyReferences
  • localDate
  • localTime
  • location
  • lowLimit
  • manipulatedVariableReference
  • maximumOutput
  • maxApduLengthAccepted
  • maxInfoFrames
  • maxMaster
  • maxPresValue
  • minimumOffTime
  • minimumOnTime
  • minimumOutput
  • minPresValue
  • modelName
  • modificationDate
  • notifyType
  • numberOfApduRetries
  • numberOfStates
  • objectIdentifier
  • objectList
  • objectName
  • objectPropertyReference
  • objectType
  • optional
  • outOfService
  • outputUnits
  • eventParameters
  • polarity
  • presentValue
  • priority
  • priorityArray
  • priorityForWriting
  • processIdentifier
  • programChange
  • programLocation
  • programState
  • proportionalConstant
  • proportionalConstantUnits
  • protocolObjectTypesSupported
  • protocolServicesSupported
  • protocolVersion
  • readOnly
  • reasonForHalt
  • recipientList
  • reliability
  • relinquishDefault
  • required
  • resolution
  • segmentationSupported
  • setpoint
  • setpointReference
  • stateText
  • statusFlags
  • systemStatus
  • timeDelay
  • timeOfActiveTimeReset
  • timeOfStateCountReset
  • timeSynchronizationRecipients
  • units
  • updateInterval
  • utcOffset
  • vendorIdentifier
  • vendorName
  • vtClassesSupported
  • weeklySchedule
  • attemptedSamples
  • averageValue
  • bufferSize
  • clientCovIncrement
  • covResubscriptionInterval
  • eventTimeStamps
  • logBuffer
  • logDeviceObjectProperty
  • enable
  • logInterval
  • maximumValue
  • minimumValue
  • notificationThreshold
  • protocolRevision
  • recordsSinceNotification
  • recordCount
  • startTime
  • stopTime
  • stopWhenFull
  • totalRecordCount
  • validSamples
  • windowInterval
  • windowSamples
  • maximumValueTimestamp
  • minimumValueTimestamp
  • varianceValue
  • activeCovSubscriptions
  • backupFailureTimeout
  • configurationFiles
  • databaseRevision
  • directReading
  • lastRestoreTime
  • maintenanceRequired
  • memberOf
  • mode
  • operationExpected
  • setting
  • silenced
  • trackingValue
  • zoneMembers
  • lifeSafetyAlarmValues
  • maxSegmentsAccepted
  • profileName
  • autoSlaveDiscovery
  • manualSlaveAddressBinding
  • slaveAddressBinding
  • slaveProxyEnable
  • lastNotifyRecord
  • scheduleDefault
  • acceptedModes
  • adjustValue
  • count
  • countBeforeChange
  • countChangeTime
  • covPeriod
  • inputReference
  • limitMonitoringInterval
  • loggingObject
  • loggingRecord
  • prescale
  • pulseRate
  • scale
  • scaleFactor
  • updateTime
  • valueBeforeChange
  • valueSet
  • valueChangeTime
  • alignIntervals
  • intervalOffset
  • lastRestartReason
  • loggingType
  • restartNotificationRecipients
  • timeOfDeviceRestart
  • timeSynchronizationInterval
  • trigger
  • utcTimeSynchronizationRecipients
  • nodeSubtype
  • nodeType
  • structuredObjectList
  • subordinateAnnotations
  • subordinateList
  • actualShedLevel
  • dutyWindow
  • expectedShedLevel
  • fullDutyBaseline
  • requestedShedLevel
  • shedDuration
  • shedLevelDescriptions
  • shedLevels
  • stateDescription
  • doorAlarmState
  • doorExtendedPulseTime
  • doorMembers
  • doorOpenTooLongTime
  • doorPulseTime
  • doorStatus
  • doorUnlockDelayTime
  • lockStatus
  • maskedAlarmValues
  • securedStatus
  • absenteeLimit
  • accessAlarmEvents
  • accessDoors
  • accessEvent
  • accessEventAuthenticationFactor
  • accessEventCredential
  • accessEventTime
  • accessTransactionEvents
  • accompaniment
  • accompanimentTime
  • activationTime
  • activeAuthenticationPolicy
  • assignedAccessRights
  • authenticationFactors
  • authenticationPolicyList
  • authenticationPolicyNames
  • authenticationStatus
  • authorizationMode
  • belongsTo
  • credentialDisable
  • credentialStatus
  • credentials
  • credentialsInZone
  • daysRemaining
  • entryPoints
  • exitPoints
  • expirationTime
  • extendedTimeEnable
  • failedAttemptEvents
  • failedAttempts
  • failedAttemptsTime
  • lastAccessEvent
  • lastAccessPoint
  • lastCredentialAdded
  • lastCredentialAddedTime
  • lastCredentialRemoved
  • lastCredentialRemovedTime
  • lastUseTime
  • lockout
  • lockoutRelinquishTime
  • maxFailedAttempts
  • members
  • musterPoint
  • negativeAccessRules
  • numberOfAuthenticationPolicies
  • occupancyCount
  • occupancyCountAdjust
  • occupancyCountEnable
  • occupancyLowerLimit
  • occupancyLowerLimitEnforced
  • occupancyState
  • occupancyUpperLimit
  • occupancyUpperLimitEnforced
  • passbackMode
  • passbackTimeout
  • positiveAccessRules
  • reasonForDisable
  • supportedFormats
  • supportedFormatClasses
  • threatAuthority
  • threatLevel
  • traceFlag
  • transactionNotificationClass
  • userExternalIdentifier
  • userInformationReference
  • userName
  • userType
  • usesRemaining
  • zoneFrom
  • zoneTo
  • accessEventTag
  • globalIdentifier
  • verificationTime
  • baseDeviceSecurityPolicy
  • distributionKeyRevision
  • doNotHide
  • keySets
  • lastKeyServer
  • networkAccessSecurityPolicies
  • packetReorderTime
  • securityPduTimeout
  • securityTimeWindow
  • supportedSecurityAlgorithms
  • updateKeySetTimeout
  • backupAndRestoreState
  • backupPreparationTime
  • restoreCompletionTime
  • restorePreparationTime
  • bitMask
  • bitText
  • isUtc
  • groupMembers
  • groupMemberNames
  • memberStatusFlags
  • requestedUpdateInterval
  • covuPeriod
  • covuRecipients
  • eventMessageTexts
  • eventMessageTextsConfig
  • eventDetectionEnable
  • eventAlgorithmInhibit
  • eventAlgorithmInhibitRef
  • timeDelayNormal
  • reliabilityEvaluationInhibit
  • faultParameters
  • faultType
  • localForwardingOnly
  • processIdentifierFilter
  • subscribedRecipients
  • portFilter
  • authorizationExemptions
  • allowGroupDelayInhibit
  • channelNumber
  • controlGroups
  • executionDelay
  • lastPriority
  • writeStatus
  • propertyList
  • serialNumber
  • blinkWarnEnable
  • defaultFadeTime
  • defaultRampRate
  • defaultStepIncrement
  • egressTime
  • inProgress
  • instantaneousPower
  • lightingCommand
  • lightingCommandDefaultPriority
  • maxActualValue
  • minActualValue
  • power
  • transition
  • egressActive
  • interfaceValue
  • faultHighLimit
  • faultLowLimit
  • lowDiffLimit
  • strikeCount
  • timeOfStrikeCountReset
  • defaultTimeout
  • initialTimeout
  • lastStateChange
  • stateChangeValues
  • timerRunning
  • timerState
  • apduLength
  • ipAddress
  • ipDefaultGateway
  • ipDhcpEnable
  • ipDhcpLeaseTime
  • ipDhcpLeaseTimeRemaining
  • ipDhcpServer
  • ipDnsServer
  • bacnetIpGlobalAddress
  • bacnetIpMode
  • bacnetIpMulticastAddress
  • bacnetIpNatTraversal
  • ipSubnetMask
  • bacnetIpUdpPort
  • bbmdAcceptFdRegistrations
  • bbmdBroadcastDistributionTable
  • bbmdForeignDeviceTable
  • changesPending
  • command
  • fdBbmdAddress
  • fdSubscriptionLifetime
  • linkSpeed
  • linkSpeeds
  • linkSpeedAutonegotiate
  • macAddress
  • networkInterfaceName
  • networkNumber
  • networkNumberQuality
  • networkType
  • routingTable
  • virtualMacAddressTable
  • commandTimeArray
  • currentCommandPriority
  • lastCommandTime
  • valueSource
  • valueSourceArray
  • bacnetIpv6Mode
  • ipv6Address
  • ipv6PrefixLength
  • bacnetIpv6UdpPort
  • ipv6DefaultGateway
  • bacnetIpv6MulticastAddress
  • ipv6DnsServer
  • ipv6AutoAddressingEnable
  • ipv6DhcpLeaseTime
  • ipv6DhcpLeaseTimeRemaining
  • ipv6DhcpServer
  • ipv6ZoneIndex
  • assignedLandingCalls
  • carAssignedDirection
  • carDoorCommand
  • carDoorStatus
  • carDoorText
  • carDoorZone
  • carDriveStatus
  • carLoad
  • carLoadUnits
  • carMode
  • carMovingDirection
  • carPosition
  • elevatorGroup
  • energyMeter
  • energyMeterRef
  • escalatorMode
  • faultSignals
  • floorText
  • groupId
  • groupMode
  • higherDeck
  • installationId
  • landingCalls
  • landingCallControl
  • landingDoorStatus
  • lowerDeck
  • machineRoomId
  • makingCarCall
  • nextStoppingFloor
  • operationDirection
  • passengerAlarm
  • powerMode
  • registeredCarCall
  • activeCovMultipleSubscriptions
  • protocolLevel
  • referencePort
  • deployedProfileLocation
  • profileLocation
  • tags
  • subordinateNodeTypes
  • subordinateTags
  • subordinateRelationships
  • defaultSubordinateRelationship
  • represents
Enums Reference​
Values for the Enums parameter can be referenced at system.bacnet.enums.*
Enums Reference List
  • DayOfWeek
  • MaxApduLength
  • MaxSegments
  • Month
Code Examaples​
Reading an Array​
Reading EventTimeStamps property from an instance 0 AnalogOutput object.
Example
ot = system.bacnet.enumerated.ObjectType.analogOutput
pid = system.bacnet.enumerated.PropertyIdentifier.eventTimeStamps
timestamps = system.bacnet.readRaw("bacnetDevice", ot, 0, pid)
for t in timestamps:
print t
Reading an Array Element​
Reading index 0 of EventTimeStamps property from an instance 0 AnalogOutput object.
Example
# read index 0 of eventTimeStamps property
arrayCount = system.bacnet.readRaw("bacnetDevice", ot, 0, pid, 0)
print arrayCount
