system.bacnet.readRaw
Descriptionβ
Read from any BACnet object not explicitly supported by the BACnet driver.
To use this function, the BACnet driver must be installed.
Please use caution when interacting directly with any BACnet device, as writing to an object may have unintended consequences and could result in data loss.
Syntaxβ
system.bacnet.readRaw(deviceName, objectType, objectId, propertyId, [propertyArrayIndex])
Parametersβ
| String | deviceName | The name of the configured BACnet/IP device instance to read from. |
| ObjectType | objectType | The numeric id of the objectType of the object instance being read from. See the objectType Reference below. |
| Integer | objectId | The object instance number to read. |
| PropertyIdentifier | propertyId | The PropertyIdentifier of the object instance being read. See the propertyId Reference below. |
| Integer | propertyArrayIndex | [optional] The array index of the property to read from. This parameter is optional and should not be used when reading from the entire array or if the property is not an array. |
Returnsβ
Nothing
Scopeβ
Gateway
Importing Classesβ
You can import classes from system.bacnet.* like you would other Python classes:
from system.bacnet.enumerated import ObjectType
from system.bacnet.enumerated import PropertyIdentifier
ot = ObjectType.calendar
pid = PropertyIdentifier.dateList
You can also iterate those system.bacnet.* packages to see all available classes:
for d in dir(system.bacnet.constructed):
print d
API Docsβ
BACnet4j Library of all classes available for import can be accessed at this link: BACnet4j Library 6.0.1 API Docs
Referencesβ
objectType Referenceβ
Values for the objectType parameter can be referenced at system.bacnet.enumerated.ObjectType.*
objectType Reference List
- analogInput
- analogOutput
- analogValue
- binaryInput
- binaryOutput
- binaryValue
- calendar
- command
- device
- eventEnrollment
- file
- group
- loop
- multiStateInput
- multiStateOutput
- notificationClass
- program
- schedule
- averaging
- multiStateValue
- trendLog
- lifeSafetyPoint
- lifeSafetyZone
- accumulator
- pulseConverter
- eventLog
- globalGroup
- trendLogMultiple
- loadControl
- structuredView
- accessDoor
- timer
- accessCredential
- accessPoint
- accessRights
- accessUser
- accessZone
- credentialDataInput
- networkSecurity
- bitstringValue
- characterstringValue
- datePatternValue
- dateValue
- datetimePatternValue
- datetimeValue
- integerValue
- largeAnalogValue
- octetstringValue
- positiveIntegerValue
- timePatternValue
- timeValue
- notificationForwarder
- alertEnrollment
- channel
- lightingOutput
- binaryLightingOutput
- networkPort
- elevatorGroup
- escalator
- lift
propertyId Referenceβ
Values for the propertyId parameter can be referenced at system.bacnet.enumerated.PropertyIdentifier.*
propertyId Reference List
- ackedTransitions
- ackRequired
- action
- actionText
- activeText
- activeVtSessions
- alarmValue
- alarmValues
- all
- allWritesSuccessful
- apduSegmentTimeout
- apduTimeout
- applicationSoftwareVersion
- archive
- bias
- changeOfStateCount
- changeOfStateTime
- notificationClass
- controlledVariableReference
- controlledVariableUnits
- controlledVariableValue
- covIncrement
- dateList
- daylightSavingsStatus
- deadband
- derivativeConstant
- derivativeConstantUnits
- description
- descriptionOfHalt
- deviceAddressBinding
- deviceType
- effectivePeriod
- elapsedActiveTime
- errorLimit
- eventEnable
- eventState
- eventType
- exceptionSchedule
- faultValues
- feedbackValue
- fileAccessMethod
- fileSize
- fileType
- firmwareRevision
- highLimit
- inactiveText
- inProcess
- instanceOf
- integralConstant
- integralConstantUnits
- limitEnable
- listOfGroupMembers
- listOfObjectPropertyReferences
- localDate
- localTime
- location
- lowLimit
- manipulatedVariableReference
- maximumOutput
- maxApduLengthAccepted
- maxInfoFrames
- maxMaster
- maxPresValue
- minimumOffTime
- minimumOnTime
- minimumOutput
- minPresValue
- modelName
- modificationDate
- notifyType
- numberOfApduRetries
- numberOfStates
- objectIdentifier
- objectList
- objectName
- objectPropertyReference
- objectType
- optional
- outOfService
- outputUnits
- eventParameters
- polarity
- presentValue
- priority
- priorityArray
- priorityForWriting
- processIdentifier
- programChange
- programLocation
- programState
- proportionalConstant
- proportionalConstantUnits
- protocolObjectTypesSupported
- protocolServicesSupported
- protocolVersion
- readOnly
- reasonForHalt
- recipientList
- reliability
- relinquishDefault
- required
- resolution
- segmentationSupported
- setpoint
- setpointReference
- stateText
- statusFlags
- systemStatus
- timeDelay
- timeOfActiveTimeReset
- timeOfStateCountReset
- timeSynchronizationRecipients
- units
- updateInterval
- utcOffset
- vendorIdentifier
- vendorName
- vtClassesSupported
- weeklySchedule
- attemptedSamples
- averageValue
- bufferSize
- clientCovIncrement
- covResubscriptionInterval
- eventTimeStamps
- logBuffer
- logDeviceObjectProperty
- enable
- logInterval
- maximumValue
- minimumValue
- notificationThreshold
- protocolRevision
- recordsSinceNotification
- recordCount
- startTime
- stopTime
- stopWhenFull
- totalRecordCount
- validSamples
- windowInterval
- windowSamples
- maximumValueTimestamp
- minimumValueTimestamp
- varianceValue
- activeCovSubscriptions
- backupFailureTimeout
- configurationFiles
- databaseRevision
- directReading
- lastRestoreTime
- maintenanceRequired
- memberOf
- mode
- operationExpected
- setting
- silenced
- trackingValue
- zoneMembers
- lifeSafetyAlarmValues
- maxSegmentsAccepted
- profileName
- autoSlaveDiscovery
- manualSlaveAddressBinding
- slaveAddressBinding
- slaveProxyEnable
- lastNotifyRecord
- scheduleDefault
- acceptedModes
- adjustValue
- count
- countBeforeChange
- countChangeTime
- covPeriod
- inputReference
- limitMonitoringInterval
- loggingObject
- loggingRecord
- prescale
- pulseRate
- scale
- scaleFactor
- updateTime
- valueBeforeChange
- valueSet
- valueChangeTime
- alignIntervals
- intervalOffset
- lastRestartReason
- loggingType
- restartNotificationRecipients
- timeOfDeviceRestart
- timeSynchronizationInterval
- trigger
- utcTimeSynchronizationRecipients
- nodeSubtype
- nodeType
- structuredObjectList
- subordinateAnnotations
- subordinateList
- actualShedLevel
- dutyWindow
- expectedShedLevel
- fullDutyBaseline
- requestedShedLevel
- shedDuration
- shedLevelDescriptions
- shedLevels
- stateDescription
- doorAlarmState
- doorExtendedPulseTime
- doorMembers
- doorOpenTooLongTime
- doorPulseTime
- doorStatus
- doorUnlockDelayTime
- lockStatus
- maskedAlarmValues
- securedStatus
- absenteeLimit
- accessAlarmEvents
- accessDoors
- accessEvent
- accessEventAuthenticationFactor
- accessEventCredential
- accessEventTime
- accessTransactionEvents
- accompaniment
- accompanimentTime
- activationTime
- activeAuthenticationPolicy
- assignedAccessRights
- authenticationFactors
- authenticationPolicyList
- authenticationPolicyNames
- authenticationStatus
- authorizationMode
- belongsTo
- credentialDisable
- credentialStatus
- credentials
- credentialsInZone
- daysRemaining
- entryPoints
- exitPoints
- expirationTime
- extendedTimeEnable
- failedAttemptEvents
- failedAttempts
- failedAttemptsTime
- lastAccessEvent
- lastAccessPoint
- lastCredentialAdded
- lastCredentialAddedTime
- lastCredentialRemoved
- lastCredentialRemovedTime
- lastUseTime
- lockout
- lockoutRelinquishTime
- maxFailedAttempts
- members
- musterPoint
- negativeAccessRules
- numberOfAuthenticationPolicies
- occupancyCount
- occupancyCountAdjust
- occupancyCountEnable
- occupancyLowerLimit
- occupancyLowerLimitEnforced
- occupancyState
- occupancyUpperLimit
- occupancyUpperLimitEnforced
- passbackMode
- passbackTimeout
- positiveAccessRules
- reasonForDisable
- supportedFormats
- supportedFormatClasses
- threatAuthority
- threatLevel
- traceFlag
- transactionNotificationClass
- userExternalIdentifier
- userInformationReference
- userName
- userType
- usesRemaining
- zoneFrom
- zoneTo
- accessEventTag
- globalIdentifier
- verificationTime
- baseDeviceSecurityPolicy
- distributionKeyRevision
- doNotHide
- keySets
- lastKeyServer
- networkAccessSecurityPolicies
- packetReorderTime
- securityPduTimeout
- securityTimeWindow
- supportedSecurityAlgorithms
- updateKeySetTimeout
- backupAndRestoreState
- backupPreparationTime
- restoreCompletionTime
- restorePreparationTime
- bitMask
- bitText
- isUtc
- groupMembers
- groupMemberNames
- memberStatusFlags
- requestedUpdateInterval
- covuPeriod
- covuRecipients
- eventMessageTexts
- eventMessageTextsConfig
- eventDetectionEnable
- eventAlgorithmInhibit
- eventAlgorithmInhibitRef
- timeDelayNormal
- reliabilityEvaluationInhibit
- faultParameters
- faultType
- localForwardingOnly
- processIdentifierFilter
- subscribedRecipients
- portFilter
- authorizationExemptions
- allowGroupDelayInhibit
- channelNumber
- controlGroups
- executionDelay
- lastPriority
- writeStatus
- propertyList
- serialNumber
- blinkWarnEnable
- defaultFadeTime
- defaultRampRate
- defaultStepIncrement
- egressTime
- inProgress
- instantaneousPower
- lightingCommand
- lightingCommandDefaultPriority
- maxActualValue
- minActualValue
- power
- transition
- egressActive
- interfaceValue
- faultHighLimit
- faultLowLimit
- lowDiffLimit
- strikeCount
- timeOfStrikeCountReset
- defaultTimeout
- initialTimeout
- lastStateChange
- stateChangeValues
- timerRunning
- timerState
- apduLength
- ipAddress
- ipDefaultGateway
- ipDhcpEnable
- ipDhcpLeaseTime
- ipDhcpLeaseTimeRemaining
- ipDhcpServer
- ipDnsServer
- bacnetIpGlobalAddress
- bacnetIpMode
- bacnetIpMulticastAddress
- bacnetIpNatTraversal
- ipSubnetMask
- bacnetIpUdpPort
- bbmdAcceptFdRegistrations
- bbmdBroadcastDistributionTable
- bbmdForeignDeviceTable
- changesPending
- command
- fdBbmdAddress
- fdSubscriptionLifetime
- linkSpeed
- linkSpeeds
- linkSpeedAutonegotiate
- macAddress
- networkInterfaceName
- networkNumber
- networkNumberQuality
- networkType
- routingTable
- virtualMacAddressTable
- commandTimeArray
- currentCommandPriority
- lastCommandTime
- valueSource
- valueSourceArray
- bacnetIpv6Mode
- ipv6Address
- ipv6PrefixLength
- bacnetIpv6UdpPort
- ipv6DefaultGateway
- bacnetIpv6MulticastAddress
- ipv6DnsServer
- ipv6AutoAddressingEnable
- ipv6DhcpLeaseTime
- ipv6DhcpLeaseTimeRemaining
- ipv6DhcpServer
- ipv6ZoneIndex
- assignedLandingCalls
- carAssignedDirection
- carDoorCommand
- carDoorStatus
- carDoorText
- carDoorZone
- carDriveStatus
- carLoad
- carLoadUnits
- carMode
- carMovingDirection
- carPosition
- elevatorGroup
- energyMeter
- energyMeterRef
- escalatorMode
- faultSignals
- floorText
- groupId
- groupMode
- higherDeck
- installationId
- landingCalls
- landingCallControl
- landingDoorStatus
- lowerDeck
- machineRoomId
- makingCarCall
- nextStoppingFloor
- operationDirection
- passengerAlarm
- powerMode
- registeredCarCall
- activeCovMultipleSubscriptions
- protocolLevel
- referencePort
- deployedProfileLocation
- profileLocation
- tags
- subordinateNodeTypes
- subordinateTags
- subordinateRelationships
- defaultSubordinateRelationship
- represents
Enums Referenceβ
Values for the Enums parameter can be referenced at system.bacnet.enums.*
Enums Reference List
- DayOfWeek
- MaxApduLength
- MaxSegments
- Month
Code Examaplesβ
Reading an Arrayβ
Reading EventTimeStamps property from an instance 0 AnalogOutput object.
ot = system.bacnet.enumerated.ObjectType.analogOutput
pid = system.bacnet.enumerated.PropertyIdentifier.eventTimeStamps
timestamps = system.bacnet.readRaw("bacnetDevice", ot, 0, pid)
for t in timestamps:
print t
Reading an Array Elementβ
Reading index 0 of EventTimeStamps property from an instance 0 AnalogOutput object.
# read index 0 of eventTimeStamps property
arrayCount = system.bacnet.readRaw("bacnetDevice", ot, 0, pid, 0)
print arrayCount
