Deprecated Vision Components
** This feature was removed from Ignition in version 8.0**
The pages under this section contain legacy documentation for deprecated Vision components. Where possible, newer components should be utilized instead.
📄️ Legacy Comments Panel
The comments panel is used to power a blog-style comments system within your project.
📄️ IA Labs PDF Viewer
This page refers to the IA Labs PDF Viewer module. This module is only available in Ignition versions 7.7, 7.6, and 7.5. For information on the PDF Viewer component available in versions 7.8 or greater, please see the PDF Viewer page.
📄️ Document Viewer - Deprecated
The document viewer is capable of loading and displaying a document that is available over the network at a URL.
