User Sources and Classic Authentication
Active Directory User Source
The SSO Enabled setting was removed and deprecated in 8.1.17 to protect against a potential security vulnerability. While the property is still visible, it cannot be enabled without setting a special system property. This is not recommended.
Active Directory Deprecated Properties
| Name | Description |
| SSO Enabled | Whether or not to use Single-Sign-On (SSO) to authenticate AD users, giving the ability to automatically log into the Client or Designer when already logged into Windows. |
Enable the Legacy Ignition Windows Active Directory Single Sign On
This is not recommended for most environments and is associated with a known vulnerability.
The SSO feature can be re-enabled by adding an additional system property to the ignition.conf file located in the Ignition install directory and then restarting the Ignition service. Check the corresponding User Manual page for more information on the file's location:
The system property can be defined under the Java Additional Parameters section by adding the following:
wrapper.java.additional.X=-Dignition.enableInsecureAdSso=true
Make sure to replace the trailing "X" of the prefix "wrapper.java.additional.X" with the appropriate value that follows the ascending numerical order of the parameter list. See user manual page on Changing Java Additional Parameters for examples.
See the Active Directory SSO Disabled for 8.1.17 & 7.9.20 article for more information.
