Database Expression Functions
The following functions allow you to interact with a database in expression bindings. These are only available in Transaction groups.
This feature was removed from Ignition in version 8.0.0
📄️ executeQuery
Executes a select query using the given ConnectionName (or the default connection it omitted) and stores the result into a global ResultSetName.
📄️ executeScalarQuery
Executes a select query using the given connectionName (or the default connection it omitted) and returns the first scalar value from the resultset.
📄️ executeUpdateQuery
Executes an update query using the given ConnectionName (or the default connection it omitted) and returns the number of rows effected.
📄️ getDatasetValueByIndex
Retrieves a value from a global variable DatasetName created using the ExecuteQuery function.
📄️ getDatasetValueByName
Retrieves data from a global variable DatasetName created using the ExecuteQuery function.
📄️ isDBConnectionAvailable
Checks if the given database connection is available. Will use the default for that scope if none is specified.
