Version: 8.3
system.tag.importTags
Imports a JSON tag file at the provided path. Also supports XML and CSV Tag file exports from legacy systems.
Permission Type: Tag Editing
system.tag.importTags(filePath, basePath, [collisionPolicy])
StringfilePathThe file path of the tag export to import.
StringbasePathThe Tag path that will serve as the root node for the imported tags.
StringcollisionPolicyThe action to take when a tag or folder with the same path and name is encountered. Defaults to Overwrite. [optional]. Possible values include:
  • a - Abort and throw an exception
  • o - Overwrite and replace existing tag's configuration
  • i - Ignore that item in the list.
List - A List of QualityCode objects, one for each tag in the list, that is representative of the result of the operation. See Scripting Object Reference.
Example #1
# This script will import a .json file containing Sine Tags from the desktop into a folder in the Tag Browser called "Imported Tags".
filePath = "C:/Users/[USERNAME]/Desktop/SineTags.json"
basePath = "[default]Imported Tags"
system.tag.importTags(filePath,basePath)
