system.tag.rename
Descriptionβ
Renames a single tag or folder.
Permission Type: Tag Editing
Syntaxβ
system.tag.rename(tag, newName, [collisionPolicy])
Parametersβ
| String | tag | A path to the tag or folder to rename. |
| String | newName | The new name for the tag or folder. |
| String | collisionPolicy | The action to take when a tag or folder with the same path and name is encountered. Defaults to Abort. [optional]. Possible values include:
Returnsβ
QualityCode - A QualityCode object that contains the results of the rename operation.
Scopeβ
Code Examplesβ
Example #1 - Rename a Folder
old = "[default]folder/tag"
new = "noun_1" # Note that the new name should not include the full path or tag provider. Just the name suffices.
system.tag.rename(old, new)
