system.tag.writeBlocking
Descriptionβ
Writes values to tags at the given paths. This function will "block" until the write operation is complete or times out. Meaning, execution of the calling script will pause until this function finishes. This is useful in cases where the tag write must complete before further lines in the same script should execute.
Permission Type: Tag Editing
Syntaxβ
system.tag.writeBlocking(tagPaths, values, [timeout])
Parametersβ
| List | tagPaths | A List of tag paths to write to. If no property is specified in a tag path, the Value property is assumed. |
| List | values | A list of values to write to the specified tag paths. |
| Integer | timeout | How long to wait in milliseconds before the write operation times out. This parameter is optional and defaults to 45000 milliseconds if not specified. [optional] |
Returnsβ
List - A List of QualityCode objects, one for each Tag path. See Scripting Object Reference.
Scopeβ
Code Examplesβ
# Create a list with the tag paths to be updated.
paths = ["[default]Folder/Tag_A","[default]Folder/Tag_B"]
# Create a list with the update values, one value for each path.
values = [1,2]
# Execute the write operation.
system.tag.writeBlocking(paths, values)
